Rough running
Old Jun 24, 2006 | 08:22 AM
Amature's Avatar
Amature
Default Rough running
Took the 70 out last night for a drive. It seemed to have a slight miss in it when we left. By the time we got home, the miss seemed pretty bad. The engine is the normal 350. Nothing special. I did replace the plugs last fall. I'm pretty sure I installed the original type plugs, but don't remember for sure. I'm thinking a plug wire is off or a fouled plug. Does this sound like a good place to start, or should I check a few other items? The points are about 6 years old. Thanks.
Old Jun 24, 2006 | 08:55 AM
Bob Onit's Avatar
Bob Onit
Did you check and make sure all the plug wires are are attached to the plugs?
This has stumped me more than once
Old Jun 24, 2006 | 01:04 PM
Amature's Avatar
Amature
I just finished pulling all the plugs & checking the gaps & their condition. The last plug I pulled, closest to the firewall on the passenger side of the engine was badly fouled. All the other plugs were nice & grayish white in color. The old plugs I removed last fall had been in quite a number of years & were pretty rusty on the outside. I don't remember any of them being baddly fouled out. I may have to swap positions & see if I have a defective plug.
Old Jun 24, 2006 | 07:54 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
If that doesn't smooth her out, try running a can of carb cleaner through the carb (q-jet?),..sometimes the carbs can gum up a bit from sitting around.
Also, a vacuum leak will cause some off idle problems.
Let us know what you learn.
Old Jun 24, 2006 | 08:00 PM
redcar1979's Avatar
redcar1979
Just putting in my 2 cents worth. Vacuum leaks have bitten me several times in the past. Good luck.
Old Jun 25, 2006 | 06:42 PM
72LS1Vette's Avatar
72LS1Vette
Do you have a power brake booster? Has it ever been replaced? When I took off the master cylinder on the 72 to rebuild it the vacuum seal on the booster shaft fell out. The engine ran noticeably rougher after starting it with the MC removed, but I should qualify that by saying the enigne has only been started a handful of times after sitting for 10 years.
If you have to replace a power brake booster it is not a fun job, but doable if you have patience. I just spent 2 afternoons lying on my back under the dash trying to thread nuts onto inaccessable bolts after changing the brake booster. I suppose the pain will be worth it if I have a properly working brake system.
Rick B.
Old Jun 25, 2006 | 06:52 PM
80 Black Vette's Avatar
80 Black Vette
Just did a basic tune-up on my '80 today. Would suggest that when you change plugs to change plug wires, distributor cap, points, condensor. You get the picture. Just my opinion.
Also suggest that at night time, with all the lights off in your garage or wherever, crank her up. Look for any arching, from the wires or anything. That stuff shows up good, in the dark. If something is arching, it will run like crap. And like others have posted, check vacuum lines.
Hope this helps.
'80 Black Vette/Travis
To Rough running
