Crate Engine
Old Jun 25, 2006 | 01:31 PM
Richard Cooper's Avatar
Richard Cooper
Default Crate Engine
I want to buy a crate engine for my 1981. I am looking for what they call the Universal 350. Does anyone have some suggestions on where to purchase a crate engine? TIA
Old Jun 25, 2006 | 01:39 PM
moosie982's Avatar
moosie982
I'd go to G.M. performance parts, or someplace that aint fly-by-night, some G.M. dealers will treat you better then others, it saves wear and tear on the nervous system if any problems arise,,,
GOOD LUCK, Peace,,,Moosie
Old Jun 25, 2006 | 02:58 PM
windsoreight's Avatar
windsoreight
I perfer Jasper or GM. I am currently running a Jasper Stage II in my vette.
Old Jun 25, 2006 | 04:15 PM
RonCantrell's Avatar
RonCantrell
4th Gear
Default Greenwood
Try this http://www.greenwoodchevy.com/specials.htm.
Old Jun 25, 2006 | 06:48 PM
fl_rider's Avatar
fl_rider
Here is a link to find a local dealer:
http://www.gmgoodwrench.com/perfpartsjsp/home.jsp
I am running a 350 / 290 HP GMPP Crate and am quite pleased with it.
Old Jun 25, 2006 | 10:13 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Richie, haven't heard from you in a while-wondered if you were still out there...two years ago I converted my Silver '75 "driver" coupe to a 4spd car. In doing so, I also replaced my original, but tired 205hp L-82 engine with that GM 1973-1985 Direct Replacement 260hp 4 bolt main 350ci for $1287. Got it from Jim Pace Pontiac Dealership in Niles, Ohio. It is a long block assembly and includes the correct style oil pan(and turned the right way for Corvette). Everything is a direct and perfect bolt up. I used my valve covers, water pump, intake, exhaust manifolds, alternator, distributor, carburetor, starter, fuel pump, flywheel, etc. Got over 7,000mi on her now and she ain't skipped a beat yet!!! Best $1287 I ever spent...
Talk to you soon, Paul Borowski
Old Jun 26, 2006 | 12:44 AM
sperkins's Avatar
sperkins
It's hard to beat Summit.
http://store.summitracing.com/partde...5&autoview=sku
Old Jun 26, 2006 | 04:54 PM
sewanhaka62's Avatar
sewanhaka62
hi i put the 290hp[same as 260 with cam change] in my 66 belair this winter..long block was $ 1525-- 260hp was $1360..gm backs it for 1 to 3 years depending on body it is put in ... it has 2 piece rear seal so you can use the flywheel you have...runs great on cheap reg. gas but no race motor[66 belair runs high 15.90s in 1/4 with afb carb
Old Jun 26, 2006 | 06:46 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Looks good Paul.
Old Jun 26, 2006 | 10:04 PM
markdtn's Avatar
markdtn
Local GM dealer, Pace, Sallee Chevrolet, Scoggin-Dickey.
To Crate Engine
