So I have a brand new battery, in perfect working order (I know this), and I just couldn't hold a charge. Maybe my Alternator is bad, right? As i'm taking the alternator out to be tested, I find this:
Damn wires just fell apart; 32 years of corrosion. Needless to say, I took the alternator out and it was also in perfect working order. Time to replace some wires!
While youre under the hood, take care of that valve cover oil leak.
See...if you post pics, youd better have thick skin...
Don't touch the valve cover. You should know what happens when you start on little minor repair and then next thing you know the body is off the frame. Wait til winter !!!
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
A leaky valve cover is the first step to a complete engine rebuild. And that leads to a body-off.
