T-Tops
Old Jun 27, 2006 | 05:16 PM
noruckus's Avatar
noruckus
Cruising
Default T-Tops
a couple of you guys and gals might allready have read a post on t-tops of mine, new Q. can a 1980 t-top fit on a 75 vette? is $200. bucks a fair price on ehay, buddy has a line on some smoked glass t's very cheap,any down side to these? thanks.
Old Jun 27, 2006 | 05:32 PM
kevinator80's Avatar
kevinator80
80 will not fit 75, different locking mechanisms.
Old Jun 27, 2006 | 05:37 PM
bextreme1's Avatar
bextreme1
St. Jude Donor '06
If the smoked glass ones are used, there could be alot of scratches or cracks on them. You should check very carefully. Where are you located??? I have a set of 75 tops that are in ok shape. They are white and would need to be painted. They are in the garage, I will check them out as it's been a long time since I looked at them.
Old Jun 27, 2006 | 06:02 PM
NHvette's Avatar
NHvette
Fiberglass Ttops are a dime a dozen.
You won't see them much on Ebay, as they never sell for much.
Post a WTB add in the C3parts forum, and you have some replies.
If all you need is the fiberglass shell, I think $50 will do it.
Old Jun 27, 2006 | 06:15 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
They can be retrofitted without much trouble. Lots of earlier C3s have been upgraded to the later full-glass tops.
Old Jun 27, 2006 | 06:28 PM
TPI BOY's Avatar
TPI BOY
Old Jun 27, 2006 | 09:03 PM
77 vette's Avatar
77 vette
I got a new ($1000.00) set of glass tops from ecklers for xmas. They are for 78-81, I have a 77. They have a different rear pin type attach point than or cars, we have a triangle bolt type rear attach point. I had to removed the chrome plate, over sized the hole in the body and change the back up plate and chrome plate to a 78-81. The new plates are like $20.00 each, E-mail Ecklers and I'm sure they will sell you what you need to convert to this. Remember you will be changing this for ever so if your into being factory correct this would not be a good idea.
Old Jun 28, 2006 | 07:11 AM
noruckus's Avatar
noruckus
Cruising
Ocala, FL. about 1 hour north of Tampa or Orlando
Old Jun 28, 2006 | 11:17 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
There's a shop on Hwy 50 in Titusville, just around the corner from Ecklers... these guys have lots of used Corvette parts.
Old Jun 28, 2006 | 11:23 AM
noruckus's Avatar
noruckus
Cruising
thanks, good to know
Old Jun 28, 2006 | 01:26 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I wish I could remember the name of that place..... they do a lot of restoration and always have a few C3s there. You cannot miss it, it's about 1/2 mile before Hwy 50 dead ends at Hwy 1
To T-Tops
