70 LT1 Gasoline?
I just finished restoring my 68 coupe, all original with L79 factory small block (350HP) and the highest octane I can get is 93 and it pings no matter what we have tried with timing, vacuum advance, etc.
I have owned this car sine 1972 and I formerly ran Sunoco 260 but it is no longer available. My car, and I would think your LT1, need high octane. I found that I can make the pinging go away by buying racing fuel (101 octane $5.75 per gallon) and mixing 2 gallons per tankful with the 93 octane and it raises it enough to be able to drive it without pinging. I tried Octane Boosters and they do not work. Everyone on this forum warned me of this but I had to try them anyway. I do not remember what the compression ratio is on the LT1 with 370 horsepower but if it is high, it will probably require high octane fuel to run properly.
I live in Massachusetts and the highest octane I have been able to find is 93, you may have better luck in your area.
Good luck, the LT1 is a nice car.
Kurt
Bullshark
The high compression motors need the high octane that is no longer available.
Kurt
There's 3 places within a few miles that sell 101-110 octane.
It's not on every street corner, but she sure does like 110....
Is it possible to back off the timing a bit and run with premium unleaded?
SEMPER FI--1970 Dave
http://kemcoindustries.com/product_info.php?pId=61
You can get your octane where you want it to be, with the added benefit of valve seat lubrication from the lead. Works fine, just be careful handling it. Lead in any form is toxic.
Your gonna need race fuel if its still a 11:1 motor.
Just got finished restoring my 70 LT-1, rebuilt motor to original specs, it's a beast compared to my 71 LT-1.
I'm able to buy 111 octane/leaded and mix it with the 93 premium/unleaded at the pump, runs awesome and no pinging. Smells really good too
!I got lucky as we have a station nearby that sells/distributes this stuff (link attached) http://www.rockettbrand.com/
Check out their website, they have a listing of dealers by state, they maybe have one near you.
Its pretty expensive by the gallon (nearing $5), but mixing it with the 93 I can get at the pump gets me close to about 104 octane or so I figure...car seems to runs great on this mix.
Only problem (at least here in WI) you can't pump it directly into your car (its against the law), so I fill up (6) 5gal cans and take 30 gal home and fill up my 30 gal fuel storage tank in the garage and hand pump/mix into the car at home when I need it....safe and secure!
Send some pics out of the 70 LT-1 if you get it! You know you gotta buy if its a straight car and the real deal! (especially if it has paperwork to prove it).
Hope this helps
Chuck
Fred
Hope this helps
Chuck
If you pump 93 octane and want 104 octane, you just add 6 ounces per gallon when you fill it up. It comes in 32 ounce bottles so it's much easier to carry around than several gas cans of race fuel. Plus it gives you flexibility to take the vette on longer drives and refuel when you need to without worrying about finding high octane stuff in strange places. There's a mix ratio matrix right on the label so it's easy to calculate. The highest boost they show is a 16 point increase, but that's adding a 32 ounce bottle to each two gallons of fuel. But if you NEED 109 octane, you can get there!
If you have any doubts, do some quick searches on tetra ethyl lead and read up on it. I did a lot of research before I bought a couple of cases. It's definitely the real deal.
Good tip....I'm gonna give the Kemco 130 Booster a try!
same here
i normally run the lead susbtitute, (makes a definate differece) and the 104 octaine boost ( may or may not be doing anything, but i use it anyway)
this stuff sounds like a step up
great tip
Good information and thank you for providing it. I also was interested in the OS130 from Kemco but wanted the opinion of someone like you, who has actually used it, so I could determine if it was any better than the snake oil the local auto parts was trying to sell me.
I will order some of this stuff and hope that it cures my problem so I can finally enjoy this car without worrying about damage.
Thank you
Kurt
Thank you
Kurt
That's the same stuff (different name) that I showed you when you were at my place. It does work and should help you out.
Paul
