Radiator Seals
Old Jun 28, 2006 | 11:42 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Radiator Seals
Has anyone made their own radiator seals. or is it cheaper just to buy the kit
Old Jun 29, 2006 | 07:37 AM
GDaina's Avatar
GDaina
buy it
Old Jun 29, 2006 | 10:04 AM
Joes80's Avatar
Joes80
probably just better off buying them, I was referred to Dr Rebuild from a few members, http://www.docrebuild.com/
not sure how much pipe insulation is in the plumbing section, but that was also an idea one of the guys gave me.
Old Jun 29, 2006 | 10:21 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
In a pinch, you can use foam pipe insulation from Home Depot or similar, sticking it to the radiator with double sided (golf grip) tape, but it looks like you used foam pipe insulation with double sided tape at the end of the day. Pop for Doc Rebuild's- it is an excellent kit!
Old Jun 29, 2006 | 11:51 AM
davidm_comp's Avatar
davidm_comp
I used some cheapo insulation used for window a/c units and doors. Works just as good, and I can get it anywhere if it needs replacing.
Old Jun 29, 2006 | 12:29 PM
markdtn's Avatar
markdtn
Buy it from Dr Rebuild. It is pre-cut, has the adhesive. Just clean off the old and put on the new.
To Radiator Seals
