Lifting a T-Top C3.
Old Jun 29, 2006 | 09:45 AM
SJW's Avatar
SJW
Default Lifting a T-Top C3.
Hi all,
A quick question for you C3 gurus from a C4 guy:
I recently had my girlfriend's '81 in my garage, and lifted the left side of the car with a floor jack centered fore/aft on the frame rail. I didn't open the door, or remove the T-Top panel. My girlfriend expressed a bit of concern that raising the car this way was somewhat risky from a chassis flexure standpoint (could fracture some fiberglass). With a ragtop, I would have had the same worries, but with the structural suppport of the T-bar on her coupe, I saw no such risk.
Obviously, in the future I'd prefer to avoid any risks, and to keep my girlfriend's mind at ease about this. Do you guys recommend opening doors and/or removing T-tops when lifting a C3 coupe in this manner?
Thanks for all advice.
Be well,
SJW
Old Jun 29, 2006 | 11:43 AM
Z51JEFF's Avatar
Z51JEFF
I think there is a jack pad at the front of the car under the bumper at the bumper support but I could be wrong,I do know the car seems like it wants to bend in half once you start raising it.
Old Jun 29, 2006 | 11:51 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
I've never had a problem with our 79, (which is close to your 81) never open the doors or remove the tops. GM didn't mention anything in the owners manual, and they built it. My 0.2
Old Jun 29, 2006 | 12:28 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I recommend using only the factory preferred jacking points. Why take the risk going another way?
Old Jun 29, 2006 | 12:54 PM
Rich_71Vette's Avatar
Rich_71Vette
I have also heard that the T-top should be removed or at least the latches opened before jacking. Any opinions on this?
Old Jun 29, 2006 | 01:02 PM
SJW's Avatar
SJW
In this case, I did it because I needed to be able to remove both wheels on the left side of the car, and wanted to place jack stands at the recommended jacking points. I couldn't put a stand at these points if the jack was there.
A lot of C4 owners heave one side of their cars up with a jack amidships on the frame rail, and as you know, C4s have no T-bar. I could see no reason to not do so on the '81, with the T-bar providing so much structural strength to the car.
Be well,
SJW
Old Jun 29, 2006 | 01:25 PM
76stingracer's Avatar
76stingracer
I jack my 76 almost every weekend to change to my hoosier race tires.
two tires at a time. Been doing this for eight years no problems.
With a good frame jacking in the middle to get both tires off the ground is no issue. Doors open or closed. T-tops in or out. The C3 frame is the structure that the body rest on. Now c4's are made different. The structure is incorporated in the body.
The problem comes when you have a rotted frame.
Old Jun 29, 2006 | 01:30 PM
ksbunting's Avatar
ksbunting
This question has come up several times before on this forum.
I have been jacking my 68 up since 1972 and I never worry about opening doors or removing t-tops.
If the car is so flexible that it will bend, you have bigger problems i.e. rusted out frame.
I have not experienced any flexing when jacking my car up from the front or the sides. If memory serves me correctly, the previous discussions on this topic all reached the same conclusion that jacking should not adversely affect the car in any way unless your frame is badly rusted. In addition, I agree with you that the t-top structure should provide additional support rather than make it more susceptible to flexing.
My 2 cents,
Kurt
Old Jun 29, 2006 | 01:36 PM
2TONE82's Avatar
2TONE82
This topic - open doors/pop tops prior to jacking the car up - comes up now and again...I maintain that something could happen and therefore always leave the doors slightly ajar and pop the tops, leaving them in place just have the tension removed.
Others state that if this was a problem GM would have mentioned it in the owners manual and you would break a top due to body flex going over speed-bumps.
In the end I believe it falls into the ounce of prevention category - my tops are still in one piece and as they aren't making them anymore I'll keep doing the above.
Old Jun 29, 2006 | 01:38 PM
frostbitten09's Avatar
frostbitten09
I woudlnt worry, i have a 78 and i have it sitting on 4 jackstands. The entire car is up and its been up on jackstands for 2 months now and no problem....
I had one side jacked up for a week then put the entire thing up, im comfortable if i had to sleep under it, and i had no problems with fiber glass.
EXEPT my passanger side door i keep open because the frame is twisted a bit and the right side is down a little bit but no worries.
Old Jun 29, 2006 | 02:12 PM
L8279's Avatar
L8279
Default T-Tops
Its my understanding that if you have the fiberglass tops on dont worry about but if you have glass tops you should take them off
Old Jun 29, 2006 | 02:18 PM
Glass Act's Avatar
Glass Act
Old Jun 29, 2006 | 02:50 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I never have a problem with my doors or tops when jacking it up. I think that if you do, you should start looking for frame or birdcage problems.
Old Jun 29, 2006 | 02:51 PM
IMA 66's Avatar
IMA 66
I jacked up the 74 this weekend from under the rear before setting it on jackstands. Didn't even realize i had left the door open went to shut it very gingerly and noticed that there was no difference shut like every other time same gap no binding.
Old Jun 29, 2006 | 03:14 PM
NHvette's Avatar
NHvette
Only trouble is if frame and/or birdcage is rotted.
If you don't know for sure, then you should release
the glass TTops - all else should be fine.
If you get cracks in the fiberglass from jacking, you have
much bigger problems than cracks in your paint. Fix the frame.
Old Jun 29, 2006 | 03:38 PM
holley505's Avatar
holley505
My father always told me to release the latch on the tops... and open the doors depending on what type of lift was used.
I can say my car has low miles 69K.... And i got a few spider web cracks in the outer corners of the short back glass....
for all you 68-77 guys out there.
BUT... TRUE C4s dont have anything like a real frame that the C2-C3 models have.
Old Jun 29, 2006 | 03:42 PM
ksbunting's Avatar
ksbunting
Holley505,
Like NHVette said above, Check your frame, you may have bigger problems than you realize. Your car shouldn't flex.
Think about all the lawsuits GM would have if these C3 frames really were so fragile that they flexed when you jack up the car.
To Lifting a T-Top C3.
Old Jun 29, 2006 | 04:32 PM
IrishJoker's Avatar
IrishJoker
It's amazing to me how this keeps coming up over and over again. Some of you guys seem to think the C3 sits on a rubber frame or something. The frame under the C3 is an independant frame - true and it's actually stiffer than the C4. The C4 flexes more when the top is off! This thing about the T-tops off and the doors open - ever watched the dealership? Don't you think if this was an issue - word would have gotten around to the dealerships to follow this procedure? I've never heard a word by GM on this subject. They tell you how to jack the car up in the owner's manual. Nothing about taking your tops off or opening doors. The truth of the matter is, this - these cars don't flex like a rubber band - jacking one side up isn't going to break you t-tops or throw your doors out of alignment.
THIS IS AN OLD WIVES TALE - MUCH LIKE AN URBAN LEGEND IN MY OPINION.
Old Jun 29, 2006 | 05:09 PM
ksbunting's Avatar
ksbunting
Irish Joker,
You are so correct.
It's almost as though some people want to find a problem where there isn't one.
I like the analogy about the rubber band frames.
Cool,
Kurt
Old Jun 29, 2006 | 05:33 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Unless the frame is rusty. I think that's where it started...people with weakened frames.
