Adhesive for installing carpet
Old Jun 30, 2006 | 11:29 AM
Maymyvetteliveforevr's Avatar
Default Adhesive for installing carpet
Since I'm installing the carpet this weekend and don't have time to find the 3M’s 8074 or 8090 Spray Adhesive as is suggested in the write up, has anyone tried regular contact cement spray? Or has anyone not used any spray at all. I'm having problems making the rear side compartment sides sit in place properly. I got the carpet from Wilcox. They suggest using the spray on the heat barrier also.
Any comments?
Frank
Old Jun 30, 2006 | 11:40 AM
noonie's Avatar
noonie
That will work great.
Spray both sides separately, allow to flash and place carpet.
Use the minimum for down the road removal.
Old Jun 30, 2006 | 11:42 AM
revel_inmy_loss's Avatar
revel_inmy_loss
I just used crappy tire spray glue...allowed to flash, worked great
Old Jun 30, 2006 | 11:53 AM
revel_inmy_loss, I just used crappy tire spray glue
Is that a contact cement type glue?
Old Jun 30, 2006 | 12:02 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
My .02, but I certainly would not use contact cement. Once set up, that stuff will not allow for the repositioning of parts. I'd use the 3M and have a little leeway in positioning, repositioning, and fitting.
Old Jun 30, 2006 | 01:12 PM
revel_inmy_loss
I believe it was... it was just what I had laying around.... I only used it to glue the kick panel pieces and console pieces on.... Again, I am building a functional car not a show car
worked good enough for me, but your standards may be a little higher
kick panels not yet installed...
Old Jun 30, 2006 | 09:08 PM
I ended up buying some 3M stuff at CTC, it gives me about 15 to 30 seconds work time. I'll see how it goes tomorrow.
Old Jun 30, 2006 | 11:03 PM
THUNDERRODENT's Avatar
THUNDERRODENT
you should be able to get the spray glue at any local parts house. Auto (TWILIGHT) Zone carries it.
Old Jun 30, 2006 | 11:11 PM
big_G's Avatar
big_G
3-M adhesive works well. Spray both surfaces and wait a few seconds before positioning. BTW, THUNDERRODENT, watch out for Ratflinger...
Old Jul 1, 2006 | 12:51 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I didn't glue any of mine in. The interior parts, sill plates, and seats hold it in place just fine.
Old Jul 1, 2006 | 12:54 PM
Muddywaters's Avatar
Muddywaters
I found the 3M in Orchard Supply works great!!! I would imagine they would have in Walley World too....
Old Jul 1, 2006 | 01:15 PM
Syco79's Avatar
Syco79
I actually didnt need any glue for my carpet I found the seats held it in place nicely. After a week it sits really nicely I have some 3m on hand though incase it gets floppy. Being in the carpet business I would have to say if you use contact cement make sure you dont plan to change he carpet again anytime in the near future . I used contact on the seat backs and lets just say its not going anywhere for a while
Old Jul 1, 2006 | 02:51 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
A friend had a Porsche 944...that was the worst stereo install of my life. The Germans glued EVERYTHNG into that car, including the interior trim panels...
To Adhesive for installing carpet
