Motor mounts help please!
Old Jul 2, 2006 | 06:06 PM
nihil's Avatar
nihil
Default Motor mounts help please!
Today has not gone very smoothly. A bunch of minor hiccups and a stupid !#$@#%%$ thunderstorm has rolled in. I scrambled to push everything back into the garage. I'm waiting for my power to go out !#$@r3kladfsj. I've got everything... ready for the motor pull except for the motor mounts. I can see two on the sides towards the front. Are there any more? If not, are there just three bolts for each motor mount? I removed five bellhousing bolts (auto transmission). I removed the three flexplate bolts. What am I missing! Help!
Old Jul 2, 2006 | 06:09 PM
ESC3's Avatar
ESC3
Just pull the main through bolt on each motoir mount and thats it.Looks like you got the rest.Just check for any wires ,linkage,ground straps you may have forgotten.
Old Jul 2, 2006 | 06:11 PM
nihil's Avatar
nihil
Thanks. I'm glad I'm not missing anything. I won't try to get the last of those three and just pull the main one through.
Old Jul 2, 2006 | 06:14 PM
ESC3's Avatar
ESC3
Five bellhousing bolts?I think you missed one.Should be 6.
Old Jul 2, 2006 | 06:17 PM
nihil's Avatar
nihil
My mistake, I did get 6!
Old Jul 2, 2006 | 06:21 PM
ESC3's Avatar
ESC3
Your good to go!
Old Jul 2, 2006 | 10:26 PM
fl_rider's Avatar
fl_rider
Default Support your transmission...
When you pull the engine away from it, it will take a dive unless it is supported.
To Motor mounts help please!
