Quick question on the differential
Old Jul 2, 2006 | 10:58 PM
breathial's Avatar
breathial
Default Quick question on the differential
I am in the process of changing the U-joints on my half-shafts. I noticed that the pinion side-yoke on the passenger side came out. Basically, that the clip that holds it in place is not present...
The drivers' side yoke stays in place, no slop there...
Now, I checked to see if there was leakage, or any kind of wear on the end of the pinion yoke that did come out, but it looks to be in very good shape... I'm trying to get it up and running, and rebuild the suspension (and detail it all out) in about six months, when I have the time to tear into it and make it all "proper."
So, my question is, is this something I can just leave be, for a little while? I've neither the expertise nor $$$ to throw at the differential right now, so I'm just trying to get it on the road, and enjoy it, for the summer... (besides, my work has me SO busy that I don't have the extra time to devote to a full-on rear end rebuild... that'll change this winter)
What do you say? Is it doable, knowing I'm gonna' go through this come winter?
Thanks in advance,
Eric
Old Jul 2, 2006 | 11:08 PM
ESC3's Avatar
ESC3
I think I'd want to open the cover and see where the clip went.If it finds it's way into your gearset your gonna be pretty unhappy and out some serious money.
Old Jul 3, 2006 | 10:24 AM
GTR1999's Avatar
GTR1999
Did you remove the yoke? If so was there still a chamfer on the end of the yoke? If so them the snap ring may hve fallen off- not likely. Most likely is the yoke is worn out and if it's at the snap ring you will have a problem.
Look over this post it will help you.
http://forums.corvetteforum.com/show....php?t=1236684
Old Jul 4, 2006 | 01:44 AM
breathial's Avatar
breathial
Yeah, the end of the yoke had a very clean chamfer on it. The end of it looks exactly like the pic you posted (less the clip itself) on page 5 of that thread... Which is the only reason why I'm considering running it for a while...
You have to know, I've been screwing around with this car for about 3 years now, and it's still not been on the road. I had decided to get it rolling, at least for a little while...
BTW, could you PM me about your rebuild kits that are mentioned in your thread? After looking at your thread on building the diff, and considering I've rebuilt everything else in the car? Well, I can't see any honest reason why I wouldn't do this, as well...
Looking forward to your reply,
Eric
To Quick question on the differential
