Anyone have a trick to get old cotterpins out of those dang castlenut holes?
I'm tearing down my front suspension to make way for the vb&p performance plus system but these ORIGINAL cotterpins don't want to come out.
If I put an airsocket gun to them will the cotterpins just sheer off without damaging the nut or bolt?
We either torqued the nuts off, which shears the pin, or we drove them out with a small punch, I wouldn't recommend shearing them off with the nut if you are going to reuse the pieces, we had all new pieces so we just sheared them, I think that you may get metal shavings in the bolt or you may mess up the threads just torquing them off, depending on how hard they are to get off. We did not notice the bolts getting messed up, but then again we were not looking to reuse them.
76custompaint
P.S. one good tip, use a scredriver or a pliers to grab onto the loop part of the cotter pins, and then either pry or pull on it to try to remove the pins, if it breaks, try to pull each individual piece out with the pliers. It did work for most of the pins we had, we did shear off a couple with the nut, but did mainly because we had new parts and were in a hurry.
I use a pair of heavy wire cutters or dikes to remove them. Straighten it out as much as possible and grab the loop part with the cutters and pry it out. Never had a problem this way.
I usually get them out Ok - but I have resorted to shearing them with
the nut and punching out after. I have never mucked up any threads
this way. The pins are usually a very mild steel and the nuts/pins are
quite hard. Still, there is a chance to mess them up (always is).
Use the heavy dykes to cut the loop and pull it out in 2 pieces
This is your best chance! Try a little heat also.(make sure your not near any fuel leaks)Next a small punch.If you use a drill remember if you break "that"off its hardened.
Once in a while I encounter one of those cotter pins that seem to be totally inaccesible for a pair of dykes, or needlenose. I just put a good box wrench on the nut and shear it off. Haven't damaged any threads yet.
If that doesn't work, then !!! I never had a problem doing it that way. I could cut a 1/4" bolt with a good set of dykes. Grip the cotter pin close to the nut and pry it out, it will come so far and then regrip it.
Don't forget to put them back in...I've found a scary number of them missing from my front end, all from "professional" mechanics in the past. Professional, my shiny metal azz...
My cotterpins are a special breed called Permanent!
They have solidified over the years within the bolt itself. I yanked, gripped, snipped, regripped, cut in half, yanked somemore, cursed and no luck. Finally I used the air gun and let the castle nut sheer the ends off. I even smacked it with a punch to get the pin out from the bolt with no luck. Tonight I will try my luck with dynamite.
Seems like I have pulled a few by driving a nail, awl, or small screwdriver through the eye. Once you have something in there to grab onto, you can usually pull them out with pliers or pry it out with a claw hammer or some big screwdrivers.
