(I'm posting this as a new thread-- it was originally part of a thread concerning how to adjust the decklid)
Using some pliers and a putty knife I tore off most of the old weatherstripping this past hour and now am left with yellow glue and bits of rubber everywhere. Any tips on removing this remaining stuff-- maybe something like laquer thinner? Although with that I'm guessing it will remove the paint as well. Maybe some kind of adhesive remover that isn't as nasty on paint?
Also-- when I install the new weatherstrip-- what adhesive is recommended?
Do you remember what glue you used? Maybe it's a dumb question because I've never installed weatherstripping but is weatherstripping glue all the same and I should just go pick some up at the auto store?
Also I'm really looking for good tips on getting off all that old glue and crud!!
Thanks-
Lacquer thinner will remove paint unless your paint is urethane. In any case, use mineral spirits, regular paint thinner or a wax and grease remover.
Use 3M weatherstrip adhesive as directed to install the new one.
