Horns
Old Jul 24, 2006 | 08:42 AM
kazco's Avatar
kazco
Default Horns
1976 Vette.
I have one horn that does not work. It is the lower horn of the two.
It is pretty rusty and the only markings I can see are Delco USA and the letter C. Could this be the note it plays? When I look up replacement horns, they show high note or low note.
Which horn do I need?
Thanks in advance,
Mike
Old Jul 24, 2006 | 11:05 AM
SizzleChest's Avatar
SizzleChest
try giving the horn a solid whack with a rubber hammer. sometimes thats all the convincing they need. not sure if it's the low or high note that you're dealing with.
Old Jul 24, 2006 | 11:58 AM
1Z87L8's Avatar
1Z87L8
i believe the bottom is the low note.
mine was also not working and i found
that it had a split in it as if it got water
in it then froze up being very close to
the road it is plausible.
in any case i replaced both of mine with
a set of Fiamm El Grande's mounted in the
stock locations and using the existing wiring.
easy enough to do and a lot louder than the
stock horns.
Old Jul 24, 2006 | 01:59 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Correct. "C" is the note. Don't know if that's the high or the low for your car, but if you order a C replacement for your year, you ought to be okay.
To Horns
