I have a 76 vette with two electric fans and a clutch mounted on the front. So why do I have an overheating issue after driving 20 min below or at 200 on the water temp? I have talked to several people and need to probably pull the hose and check the thermostat. I just thought I would get a few more thoughts.
with your engine hot and idling, with the fans going, open your hood about 4 inches. You should feel the hot air just blowin' out the opening. If not, your fans aren't pulling enough, if so, your radiator or thermostat isn't doing it's job. Pull the thermostat out and see if it makes a difference. With the engine cold, start her up with the radiator cap off. You should see some serious movement of coolant, especially when you rev it. If not, you need a new water pump. My small block with just a flex fan, no clutch, with a stock copper re-cored radiator never gets even near 200 degrees. I do have the open L88 scoop which really evacuates the heat though.
On the freeway it seems to stay under 200. If I go to idle after driving for 10-15 min on the freeway then it starts to spike. If I am driving around town it will gradually start to overheat.
What engine do you have?? Mine does the exact opposite. Around 200 on highway after about 1/2 hr. at over 70 but then when I slow down it cools down fairly quickly to 180. I have a 350 rebuilt to 330HP and only the stock radiator, although it's a new one.
its a 350 rebuilt with what looks like a fairly recent replaced radiator. I am wondering if it has a thermostat on it and if that is the reason it isn't cooling well. I am going to pull the hose off in the next couple of days to check. I have already checked the local auto stores for a replacement. I really don't want to replace the radiator just yet.
I have heard different opinions about thermostat vs no thermostat and the response to cooling the engine. Some say it is necessary to cool the engine properly. Others say it shouldn't matter and that the problem lies somewhere else. The only thing it leaks is tranny fluid. I have tightened the pan but it still drips. I am looking for a replacement gasket as a backup. Looking to try tightening once more before I do.
You might want to check to see if there is any air in the system. I know cars overheat from that. With 2 fans and a good radiator, you should have no overheating problems. Check for air and any blockages in the system. Check the hose to see if it is collapsing. Also, take th radiator cap off and see how the flow is. If there is a thermostat, when it opens you should see water levelgo down and circulation.
Had the same symptoms with my 76 and I am pretty positive it is the radiator seals. With the clutch fan, at low speeds it is sucking air through the radiator to keep cool. At the higher speeds the clutch fan stops almost completely and expects air to push through the front of the radiator. The upper radiator seals were missing completely so I got new ones and they arrived today Without the seals the air will flow right past the radiator at the higher speeds and will not flow through it to keep it cool. I will be installing them tonight but I fully expect this to be what will bring down my temps at the higher cruising speeds. Important to make sure the lower air dam is also intact and working properly.
Good idea to change/add thermostat...and flush your rad....I run 200-205 in 110 F weather highway(78 SA)...195-197 or so traffic with just a clutch fan..
I run 200-205 in 110 F weather highway...195-197 or so traffic with just a clutch fan..
Poor poor you It gets up to 110F where you are at? Holy Crap!!!! I think I would burst into flames if I came out there. I cannot even visit my relatives in Charleston SC in the summertime because it is too hot for me. It was 40 when I woke up this morning
We have had record high temps on/off for over 40 days straight...if nothing else,it's a good test on the vettes cooling systems and I'm not letting them sit in the garage....but our humidity is lower than South Carolina..by a bunch..it was 113 F here last week.....cool today..only 95...
Thats true about the humidity. The humidity in Charleston SC is usually like 90-%100. At least where I am at we get about %20 humidity and it is always cool You should get a chance some year to attend the 'Vettes On The Rockies' event which is this week. Would be a good chance to get out of the heat for a week in the summer.
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
your symptom is classic if air going "around" radiator and not "through" make sure your seals etc are in place - mine had same symptoms till I stopped air from going over the radiator instead of through it.
