Ls1 Users, Please Chime In
Old Jul 26, 2006 | 10:48 PM
Crazy81's Avatar
Crazy81
Default Ls1 Users, Please Chime In
OK, now I have my vette LS1 and have to decide how I'm going to mount it. Seems like most guy's are using an offset adapter to do this. I know this would be the easy way but I would like to keep the complete serpentine belt drive. The only thing in the way is the A/C compressor on the bottom. So, I was thinking of hacking out the original frame mounts, getting a set out of a salvage C5, and cut, weld, grind and curse in a new set of frame mounts.
Before I go to the trouble of doing all the measuring, aligning and hanging the engine over the frame just to find out I won't gain anything anyway. I'd like to here from some of you LS1 guy's out there. Has anyone done it like this? Am I being stupid for thinking like this?
I welcome all feedback, even the smartass ones (as long as there funny to somebody).
Pics from any C3 LS1 in the car would be great. Especially if somebody has some from underneath.
Old Jul 27, 2006 | 09:47 PM
Crazy81's Avatar
Crazy81
Am I on my own here?
Ya'll could at least me.
Old Jul 27, 2006 | 10:41 PM
SuprJames's Avatar
SuprJames
I looked at using a Corvette's mounts and they were all over the A-arms if I remember right. Anyway, There was no even remotely simple way to mount it using the C5 mounts.
As for the accessories, the Camaro accessories will bolt right to the car accept for the AC which you can purchase a bracket for it from S&P. I'm using a Corvette engine with a C5 Magnuson supercharger and some modified Camaro brackets that line it up with the pulleys on the Vette. I think you can get the entire front system off the Camaro for around $500.
Here's a pic of a friend's Camaro LS1 sitting in my frame with the offset adapter you were talking about.
Old Jul 27, 2006 | 10:55 PM
PatsLs1vette's Avatar
PatsLs1vette
Like super james said,the camaro/firebird accessorys are the way to go,im not really sure about the c5 motor mounts,but dont think they would fit without alot of work.
Old Jul 27, 2006 | 11:09 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Waste of time go that far. It would be easier to just hack out the sub-frame and make a tube one. Why, just to save a bunch of easy to replace brackets. I would sell the vette brackets and buy some F-Body brackets. Your going to need the time elsewhere.
Vettedan sells a great motor mount.
What's your email for pics.
There's a few pics in My Corvette Photos and on my website.
Old Jul 27, 2006 | 11:12 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Forgot website.
Old Jul 28, 2006 | 01:28 AM
Crazy81's Avatar
Crazy81
Thanks for the info guy's, I think ya'll saved me a lot of grief.
Great pic superjames. Sounds like you have an awsome setup. I'd eventually like to supercharge myself. Is it fast enough for you?
Budman- I checked out you pics, Great shots. I can be emailed by clicking on my avatar.
Pat- did you get your L88 hood yet? Keep me posted on that.
BTW- Can I use the Vette oil pan or do I need to get one from an f-body?
Old Jul 28, 2006 | 06:38 AM
PatsLs1vette
I think a few guys used the vette oil pan,becuase i asked the same thing but cant remember if they had stock steering or rack and pinion,im sure someone will chime back in again.Nope no hood yet,been busy working every weekend plus my little guy has been sick so taking care of him too.
Also if anyone needs a LS1 fbody alternator brackets i have an extra set for sale.And a c5 main belt tensioner almost new 350 miles and a balancer for a c5.
Old Jul 28, 2006 | 08:13 PM
79ls1's Avatar
79ls1
If it's a vette motor and you want to change to f-body brackets, you'll need to change the balancer pulley. There is a different offset between how much the vette pulley and f-body pulley stick out from the engine. I'd also stay away from S&P brackets, not the greatest quality. Stay stock or go with March. I've never had March but it has to be better than S&P.
Yo Pat, which brackets do you want to sell and how much?
Old Jul 28, 2006 | 09:38 PM
SuprJames's Avatar
SuprJames
Unfortuanetly I've run into quite a few little hassles here and there so it hasn't gotten much past where you see in the pic. I should have chassis complete in a month or so minus brakes. Still haven't decided on that
The Vette's pan won't work with the stock steering. Both work with R&P though. I believe, but I'm not sure, the F-Body will work with the stock steering.
Old Jul 28, 2006 | 10:03 PM
Crazy81's Avatar
Crazy81
I was thinking of changing to R&P anyway. If I can't use the stock vette belt set up, I will probably go with a complete marh system. The funny thing is, I specifically shopped for a vette engine because I thought the accessories would fit better than an f-body.
Are any of y'all running A/C right now? If so, I'd be interested in how you routed your hoses.
Thanks for all ya'lls help.
Old Jul 28, 2006 | 10:24 PM
PatsLs1vette
Yo Pat, which brackets do you want to sell and how much?[/QUOTE]
i sent you a pm.
Old Jul 29, 2006 | 08:54 AM
SuprJames's Avatar
SuprJames
Ya, I bought a Vette engine thinking the same thing. Then, I made matters worse by buying a C5 supercharger off of Ebay instead of a hot rod style so then I HAD to use the balancer.
I'm going to try running the Street and Performance AC kit with the rear exit sanderson compressor. The only thing I'm worried about is whether I'll have adequate belt coverage on the supercharger pulley.
Old Jul 29, 2006 | 11:14 PM
martinsw's Avatar
martinsw
I just used the offset adapter plates - low cost, easy, everyone seems to use em.
I test fit my 01 vette engine and have one direction turn issues with the batwing oil pan and stock power steering (looks like if no power actuator would fit fine - but I like PS). Thinking of cutting the oil pan and welding (bubba max), or going F body pan (looks like would fit with stock ps).
I also am planning on trying to mod / fab brackets for upper pass side AC and upper driver side ALT (and ps and idlers). Don't want to have to change balancer and go f body brackets, but might end up that way.
Sure wish I had taken the advise to get complete f body LS1, but got a good deal on 01 vette LS1....
Old Jul 29, 2006 | 11:45 PM
Crazy81's Avatar
Crazy81
How much can you get for the vette brackets and pullys? I priced the march performance setup, $1300. I'm thinking it might be worth it to save the extra headaches. Plus, it does look nice.
BTW- How do I contact Vettedan?
Old Jul 30, 2006 | 12:58 AM
70 LS1's Avatar
70 LS1
www.vetteworksonline.com
Old Jul 30, 2006 | 01:01 AM
70 LS1's Avatar
70 LS1
I am using the stock F-body pan without notching it. Also I am using modified F-body brackets and moved the alternator to high on the driver's side.
To Ls1 Users, Please Chime In
Old Jul 30, 2006 | 02:03 AM
SuprJames's Avatar
SuprJames
Why did you move your altenator and what did you do with the power steering pump?
Old Jul 30, 2006 | 06:54 AM
PatsLs1vette
Not bubba really,alot of guys cut there ls pans when doing conversions in anything i cut my ls truck pan to work for me.
Old Jul 30, 2006 | 04:24 PM
Crazy81's Avatar
Crazy81
Cool. Found them, Thanks
