Hot inside
Old Jul 27, 2006 | 10:27 AM
SAG's Avatar
SAG
4th Gear
Default Hot inside
My 75 is hot inside, I have read about a shutoff in the heater hose, does anyone have a photo so I could see where this is done.
Old Jul 27, 2006 | 11:06 AM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
I put mine in on the 5/8 return hose. Don't have a pic handy, but you simply cut the hose and clamp the valve in-line.
I don't seem to have a big heat problem, but I live in Va and drive the car on weekends only. There are many, many threads related to the heat topic, many causes and remedies. There is a very detailed thread active on the tech board right now with great pic's on insulating the trans tunnel etc...
My suggested would be to loop the heater hose at the engine for a quick test. If that eliminates your issue, then thats you fix...else you have to start looking at other potential causes..
Old Jul 27, 2006 | 06:33 PM
omc's Avatar
omc
Default hot inside
go to napa parts house and they have a very simple vlv. that you just have to cut one hose and use 2 clamps and you are done. the cost is about $20
To Hot inside
