dipstick with headers
I don't have any problems with it, just thought it might be nice to secure it a little.
Thanks-
Andy
It all started when I tried to slide my header down over the dipstick tube and gave it a nice bend. No problem I thought, just bend it back once the headers are on. Well, every time I checked the oil, I could feel a little wobble, then one day, it just fell off.
The tube is a two piece setup, on piece is inside in the bottom of the block into the pan, the other is the upper tube that is press fitted into the block. Mine just so happened to basically break flush with the block leaving just the press fit end inside the block. It took me hours to get it out. After trying everything, I ended up stuffing a foam earplug down the hole to keep s**t out, then I had to run a tap in the hole and put some threads in. If I remember correclty, I ended up using a metric tap because it was the perfect fit. I then got a bolt with the same thread and ground the head down so I could fit a slide hammer on the end of the bolt. Last step, screw the bolt into the newly cut threads, put the slide hammer on, and pound it out. What a PITA....
Good luck, because if its loose, your most likely going to have to replace it.
