Windshield wiper door actuator
Old Aug 1, 2006 | 09:58 AM
nihil's Avatar
nihil
Default Windshield wiper door actuator
The windshield wiper door actually works (well it did, as my engine compartment is now empty) on my car. It's the early 1969 giant can style. The cannister itself is dented, bent, and rusted. Does anyone sell just the outside cannister so that I can replace it instead of buying a whole new actuator? I can't seem to find one at the usual suspects.
Old Aug 1, 2006 | 01:30 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
They are sealed units. Not sure they can be rebuilt. When they fail, most folks just replace them.
Old Aug 1, 2006 | 02:25 PM
nihil's Avatar
nihil
Darn. Works like a champ, just looks really bad. Will the late '69 wiper door actuator swap in?
Old Aug 1, 2006 | 03:06 PM
CAGregK's Avatar
CAGregK
You could do bodywork on it and then prime and paint it,or spend $120 for a new one.
Old Aug 1, 2006 | 03:23 PM
pws69's Avatar
pws69
Yes, but I believe you will need to use a different "turnbuckle" type nut to join the two shafts as they are not matching sizes on one of the combinations (does that make sense?).
Old Aug 1, 2006 | 06:51 PM
nihil's Avatar
nihil
I think so, thanks. That nut that is really long?
Old Aug 1, 2006 | 10:23 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
The bracket that mounts to the firewall is also different.
Old Aug 2, 2006 | 03:52 AM
CAGregK's Avatar
CAGregK
The rod coming off the actuator is the same..the 68's used a smaller diameter rod off the back of the actuator. You will need the late 69 and up mounting bracket.
Old Aug 2, 2006 | 09:13 AM
pws69's Avatar
pws69
Sorry, I thought the 68 and early 69 had the same size rods and the late 69 was the larger (same size rod on the actuator and door). Live and learn!
Old Aug 2, 2006 | 09:14 AM
pws69's Avatar
pws69
Yes, that one - but my point may be moot if in fact the rods are the same on early and late......
Old Aug 2, 2006 | 09:16 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
not legth, but diameter perhaps
the old can style came with two different thread diameters, the late one was larger, i beleive the larger dia, was the same size and the newer style canister, but that is what you will have to check
aslo the bracket as stated above
Old Aug 2, 2006 | 10:25 AM
pws69's Avatar
pws69
Length is what I was referring to - he is correct.
Old Aug 2, 2006 | 10:31 AM
sweethence's Avatar
sweethence
even a broken clock is right twice a day
Old Aug 2, 2006 | 10:35 AM
pws69's Avatar
pws69
What????
Old Aug 2, 2006 | 10:37 AM
sweethence's Avatar
sweethence
What????
when you said he that is me was correct
my response was meant to imply that i occasionally get things right
Just my droll sense of humor
Old Aug 2, 2006 | 12:05 PM
pws69's Avatar
pws69
Got it!
Old Aug 2, 2006 | 01:11 PM
nihil's Avatar
nihil
Looks like the solution here is clear. Paint the dented and bent housing, wait for it to fail and then worry about it!
To Windshield wiper door actuator
