75 power steering leaking
Old Aug 4, 2006 | 01:50 PM
uksailmaker's Avatar
uksailmaker
Default 75 power steering leaking
When I purchased 2 months ago with 65,000 orig miles, Fluid was leaking out in one day????
Got under and discovered the hose had big leak......Replaced hose and
Now there is a drip from the bottom of the reserviour / pump. I can not see where it is coming from ...maybe the from belt side....it seems to just appear as a drip on the bottom
Yesterday, I have put in some steering stop leak ......for the seals.....
Any ideas ???????/
Do I take off and replace seals or buy new...?????
THANKS
Loving my C3.......cant believe how much attention I get with my daily driver.......
Old Aug 4, 2006 | 02:39 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Did the stop leak solve your problem?
If you still have a leak, I suppose replacing the seals would solve your problem, but most folks do not go to that much trouble. Unless you are concerned with originality, swapping pumps is the answer.
