Rear emblem ID help...
Old Aug 5, 2006 | 09:00 PM
sperkins's Avatar
sperkins
Default Rear emblem ID help...
Check out the emblem in the photo below. What the heck is this from? I've checked every book I can find and I have no idea what this is. Any help appreciated as it needs to be replaced.
Thanks.
SP
Old Aug 5, 2006 | 10:02 PM
own2vettes's Avatar
own2vettes
Possibly a 75 gas cap door emblem?
Old Aug 5, 2006 | 10:20 PM
fl_rider's Avatar
fl_rider
Default 1975 - 76 Gas Door Emblem
http://www.madvet.com/shop?frame=4.44.1485
Old Aug 6, 2006 | 01:07 AM
sperkins's Avatar
sperkins
This thing really has me licked. It even has the bend in it to flow with the curvature of the back end. I should have glassed the holes and replaced it with the letters I guess.
Anyone else?
Old Aug 6, 2006 | 01:43 AM
vettebuyer6369's Avatar
vettebuyer6369
Anyone else?
Looks like a '62 nose emblem to me (that Bubba bent before he stuck it on).
Replace it with the letters.
Old Aug 6, 2006 | 01:52 AM
sperkins's Avatar
sperkins
Originally Posted by Vettebuyer5863
Looks like a '62 nose emblem to me.
That's exactly what it looks like. Good job!
Old Aug 6, 2006 | 06:40 AM
fl_rider's Avatar
fl_rider
Default 1962 Front Nose Emblem
http://www.madvet.com/shop?frame=4.44.1407
Old Aug 6, 2006 | 01:03 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I kinda like it. Something different.
Old Aug 6, 2006 | 06:04 PM
vettebuyer6369
I'm ready for my gift certificate.
Old Aug 6, 2006 | 09:27 PM
sperkins's Avatar
sperkins
I was hoping I wasn't the only one.
Old Aug 6, 2006 | 09:36 PM
PRNDL's Avatar
PRNDL
Perfect timing!!!! Take that silly thing off your 68's butt and send it to this guy in Iraq:
http://forums.corvetteforum.com/show....php?t=1463793
He can mount it on their Hummer!
I am... maybe ... 54 - 56% serious about this suggestion, so feel free to ignore me! If you need glasswork and paint to remove it, might be too much trouble to put the letters on.
Old Aug 7, 2006 | 10:48 AM
own2vettes's Avatar
own2vettes
I'm sticking to my original guess. Looks like a 75-76 gas cap emblem from here.
Old Aug 7, 2006 | 01:18 PM
sperkins's Avatar
sperkins
Sorry. But this is definately it below. Kudos to Vettebuyer5863.
Originally Posted by fl_rider
Old Aug 7, 2006 | 04:40 PM
vettebuyer6369
Look closer. The '62 is open and shows his red paint through the emblem. A '75 gas emblem is solid and has a "starburst" in the red that is not on his car. Plus, the flags are clearly larger on his car, the same dimensions as the '62. No "Corvette" written under the flag, either.
Old Aug 8, 2006 | 09:25 AM
own2vettes's Avatar
own2vettes
Yeah, I just put my glasses on. It does look as though the red "inside" the emblem is the color of the car coming through the hollow portion. Uncle!!! Uncle!!!
Old Aug 8, 2006 | 09:41 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
dam beat me to it
i was thinking of putting this above my giils
Old Aug 8, 2006 | 10:42 AM
own2vettes's Avatar
own2vettes
While were on the subject of rear emblems I need help. My 75 vert pictured in the avatar does not have a rear emblem. The original back cap got replaced years ago with an aftermarket one. The replacement got painted to match the car but the back cap is smooth and does not have the recesses/holes for the emblem. I have driven the car for quite some time like this but it is slowly starting to bug me. I am not very handy so I cannot probably handle a complicated fix like drilling holes etc. without probably botching up the paint. I'd like to simply afix a flush mounting emblem on the back between the tail lights. I was thinking of something like a 84 "CORVETTE" emblem as this will just stick on. Anybody have any other creative ideas? The car is a driver so I'm not concerned with keeping it original; I just want something that'll look nice and close up that gap between the tail lights.
To Rear emblem ID help...
Old Aug 8, 2006 | 10:48 AM
sweethence's Avatar
sweethence
Nothing complicated about it, just place some painters tape over the cap, mark your holes and drill, just remove the cap from the car, place on table and drill from the back side with the tape on the painted side to prevent damage
Old Aug 8, 2006 | 11:13 AM
sperkins's Avatar
sperkins
You should make a template first out of cardboard or plastic to make sure you drill the holes in the right spot.
You could also try to grind off the pegs on the back of your emblem and use double sided sticky tape.
Old Aug 10, 2006 | 02:01 PM
own2vettes's Avatar
own2vettes
Probably the easier thing to do.
