brake lights dnt work...
Old Aug 9, 2006 | 02:33 PM
badboyr6's Avatar
badboyr6
Default brake lights dnt work...
its me again...how do i fix brake lights that dont work when the pedal is depressed while the car is running? the light bulbs are brand new...
Old Aug 9, 2006 | 04:08 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Bad contact somewhere.
Bad ground.
Bad switch.
Blown fuse.
Old Aug 9, 2006 | 04:14 PM
JoeRags's Avatar
JoeRags
Check the wire that connects to the brake fluid distribution block... it probably fell off.
Old Aug 9, 2006 | 05:32 PM
GTR1999's Avatar
GTR1999
Use a 12vdc test light and have someone press the pedal. Check for power on the wire into the socket, the black wires are grounded together and rust and break. If you have 12 vdc there then rig up a test wire to a good ground and ground the socket to see it the bulb lights up. If you don't have power back trace to the fuse block.
Old Aug 9, 2006 | 07:43 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
I'd start with the brake light switch.
Old Aug 9, 2006 | 09:03 PM
tzeller's Avatar
tzeller
Old Aug 9, 2006 | 09:11 PM
noonie's Avatar
noonie
Try this previous thread
http://forums.corvetteforum.com/show...65&postcount=2
Old Aug 11, 2006 | 09:19 AM
badboyr6's Avatar
badboyr6
Default .
i dont have the the brake fluid distribution block wire put on...i tried putting it on and it doesn't want to go...its like a wierd looking circular wire....
To brake lights dnt work...
