t-tops
Old Aug 9, 2006 | 10:03 PM
Silver02's Avatar
Silver02
Default t-tops
Has anyone had a body shop bond the t-tops of a C3 together so it's like a coupe? I want one to get a C3 but can't handle the stories of leaking tops.
Old Aug 9, 2006 | 10:06 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
If the t-tops were bonded together, you couldn't remove them.
You can buy a one piece aftermarket top called a "Astrotop". Some people love them, but it seems most dislike them.
A C3 with good weatherstripping and the tops and windows lined up properly won't leak.
Old Aug 9, 2006 | 10:25 PM
PhotoVette1's Avatar
PhotoVette1
Old Aug 9, 2006 | 10:43 PM
trw's Avatar
trw
I agree, I think if you bond them they will crack with the body flexing.
Terry
Old Aug 9, 2006 | 11:14 PM
vettebuyer6369's Avatar
vettebuyer6369
Old Aug 10, 2006 | 12:39 AM
Bob Onit's Avatar
Bob Onit
My current 73' doesnt leak one bit and neither did the one I owned previously.
Im sure if you took a survey I would think that leaking is not a big issue with T-tops
With proper maintainance and care they are very stable and the parts are easy to come by and not expensive.
Old Aug 10, 2006 | 12:45 AM
Enersis's Avatar
Enersis
my t-tops dont leak at all
Old Aug 10, 2006 | 01:10 AM
Silver02's Avatar
Silver02
I guess as long as they're in good condition, they're not a problem.
Old Aug 10, 2006 | 01:55 AM
vttedrm's Avatar
vttedrm
As far as I know, C3's with t-tops are coupes.
Old Aug 10, 2006 | 05:58 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Mine leaks all around the window, but the tops don't leak.
Old Aug 10, 2006 | 08:35 AM
2TONE82's Avatar
2TONE82
Most leaks can be fixed as it is simply an adjustment between the window and T-Top...assuming the weather striping is good. Mine leaks on the passenger side at the front corner because the factory weather strip along the A-pillar is too low, the glass and T-Top weather strip mesh fine.
It only leaks when I wash it though...never sees rain as these cars will melt
Old Aug 10, 2006 | 08:46 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by vttedrm
...C3's with t-tops are coupes...
Old Aug 20, 2006 | 09:35 AM
IDOXLR8's Avatar
IDOXLR8
If the tops are adjusted correctly with new weatherstrips they will not leak. You will have other issues like the windshield and door glass to look at. As far as the single piece set up I wouldn't do it for many reasons. The coupe was designed for two tops that do flex in the channels and the single piece top will work correctly and many times have squeeks. I could give you for information on this but it may bore you, bottom line stay with the set up you got and fix the problem correctly, AL.
Old Aug 20, 2006 | 10:10 AM
kidneyboy's Avatar
kidneyboy
Mine don't leak, of courseI've never driven it in the rain.
Old Aug 20, 2006 | 01:20 PM
my red 81's Avatar
my red 81
Old Aug 26, 2006 | 01:29 AM
IDOXLR8's Avatar
IDOXLR8
Hit and run? What is the out come? Did you fix the problem? AL.
Old Aug 26, 2006 | 08:34 AM
allhans's Avatar
allhans
You don't want to do this.
Old Aug 27, 2006 | 09:26 AM
IDOXLR8's Avatar
IDOXLR8
???????????? AL.
To t-tops
