Help me solve an argument.
A given engine will put out a certain amount of torque. Make the engine bigger and it can put out more torque. Bigger apples - bigger apple pie.
Ignoring the unit conversions and efficiencies for the sake of discussion, the HP is the product of torque and RPM. Torque x RPM = HP. Bigger torque gives you bigger power but so does bigger RPM.
Because HP is torque multiplied by RPM, you can get more power from the same amount of torque if you make the same amount of torque at a higher RPM. This is why we pick aftermarket cams... because we want to move the torque curve higher up the rpm band - to make more power.
Start with a stock engine baseline. If you increase the bore and stroke with all else being equal, you will get more torque everywhere and since bigger torque x same RPM = bigger HP! You have more torque now, so the HP is now bigger.
If you want even more HP with the new bored and stroked setup, you can change the cam to move the same peak torque to occur at a higher RPM. Cams basicaly move the torque peak around the RPM band with all else being equal. Since this new cam will have your peak torque moved up to a higher RPM, you get more HP. Bigger torque from the bore and stroke plus multiply that bigger torque by the higher RPM where the torque peak exists = yet even more HP. Simple math really.
It's all about the stickers after that.
-Mark.
If you use the metric system it''s a different constant (the graphs cross at an rpm of somewhere in the 7000s..forgot the exact number
5252 is the rpm # where a dyno graph has intersecting HP and TQ lines...but only if both are plotted on equal scale)
Yeh, I know what you mean
Sure wish I hadn't open this thread....talk about mental ************
Sort of reminds me of what makes your light bulb light.....Volts or amps..
Bullshark
Bullshark
Thats easy "THE SWITCH" makes it light.
Larry
Bottomline...the acceleration you feel is only possible due to the activation of excess power that is not being used in the current state of motion.
These are both Big Blocks! Turn the volume up!
Zero to 450 mph / 9 seconds - then continue to 900 mph prior to one minute!
http://raf.union.rpi.edu/downloads/f18_ride.wmv
http://www.unl.edu/afrotc/cadet/videos/B1B.MPG
enjoy..........
Very cool.
Best explanation I have heard yet.Horsepower is a measure of the ability to do work over time.
You can't just look at peak values for HP & torque. The key value is area under the torque curve. Peak values are simply a snapshot at one RPM, and don't tell the whole story.
This is high school physics, not rocket science.
Some people never had physics. Some may have taken the class so long ago they don't remember much. Then threads like this pop up and make things even more confusing. I prefer to think of Torque as force and Horsepower as the rate of doing work.
At the drags, it's HP that's king.
Disagree? Ok, on the dragstrip you shift 200 RPM past peak torque and I'll shift 200 RPM past peak HP and we'll see who wins.
Still disagree? A diesel engine will out-torque most any gasoline engine, all things equal. Do you see any Vettes or Camaros at the drags with a Cummins diesel?
There is no comparison
Yes a 380HP Cummins with 855 cubic inches will produce over 1,000 pounds of torque... It also weighs around 2,700 pounds........ plus it wont fit in a camaro
let the other team score quick so they can get their offense back on the field...it worked one yr...
