Is there a performance advantage for the Vette such as lighter weight or more weight on the rear tires over the Camaro if both had the same motor (700+ rwhp)?
Depends where you're looking to use the performance. On a track a vette should generally nearly run circles around a first gen camaro. At the drag strip, camaros with their live axle should have quite a bit of an advantage.
I have a 69 Vette and 69 Camaro. Both are big blocks. When you look at where the engines are in relation to the front axle centerline, the Vette engine is set much further back. This means you should have a larger percentage of the vehicle weight on the rear. From my experience, my Vette gets more traction than the Camaro. However, the Vette is more prone to axle hop than the Camaro.
I think when you get into the 700+ HP level, it's really going to depend on how you setup each car. A stock Camaro suspension will not put down that much power, and neither will a stock Vette. If you're read Hot Rod over the past two years, you will see that a Vette with an IRS can be setup to run with just about any "street" car.
Depends on what you mean by performance. I see the vette as a sports car...
The vette has better weight distibution - almost 50/50
The vette has better rear suspension - IRS vs straight axle
The vette has better brakes - 4 wheel disc vs disc/drum
The vette has lower center of gravity
The vette is approx 3300 lbs. vs ???
all but the last are significant advantages if you are building a pro-touring car. Not sure if there are advantages for a drag racer.
I have them both. Dont bet against the Vette! Aero dynamics and weight to the Vette all day long. A Camaro front end is like pushing a barn door down the strip.
The aftermarket is much more supportive of the Camaro. With 700hp you may be considering some aftermarket goodies at some point. The Camaro may have bolt-in parts available, where the vette may require custom work.
Either way, it's going to be a BBC with an intercooled turbo so it's probably going to be well over 700 rwhp. It will be a street only car. I just want something real fast. Traction will be a major problem. Probably going to have to run drag radials. Brakes, tranny, and rear end will all be upgraded. Love the Vettes but under hood area is tight. Need to fit a 91mm turbo, 502 BBC and as big an intercooler as possible.
As far as buying one, I'd love to get either one with a blown motor cause it's not going to be used anyway.
I own three 69 Camaros and the 73 Vette and basically agree with the above.
For road or slalom racing the Vette is much more suited (it is a sports car after-all), but on a drag strip, the Camaro is the choice,..12-Bolt rear, solid axle, more room under a stock hood, more room for headers/exhaust, and make no mistake, my 69 Camaros are muuuuch lighter than my Stingray.
Vettes are full frame and Camaros are uni-body so Camaros need sub-frame connectors with HP over 400,..no big deal though.
Vettes weren't made for drag-racing,..I'm not sure how much HP the IRS and/or the 8.4" rear end would take at the drags with slicks,..maybe 400 at the flywheel? With slicks a first gen Camaro rear could easily take 5-550 with a 12-bolt and slapper bars,..or better yet, Cal-Tracs.
Brakes? Not used during a drag race, but the Vette wins the deceleration battle hands down.
Do the vette, EVERYONE does freakin Camaros. NO stock type setup is gonna hold 700rwhp anyway. You can build up an IRS and suspension to take the abuse, it may not plant it or weight transfer as well as a straight axle car but..they can take it. My buddy's 66 puts about 600-620 rwhp on spray and he 60's mid 1.6s with it on drag radials and a 5 spd.
Vettes are WAY cooler then camaros anyway. 502 turbo would be an awesome show stopper in a vette. Make sure you get a 68-72 vette to do it on though.
If you dont want to build one [Camaro} i`ll sell you a 68 SS that may be exactly your style as a street piece. 1/4 mile raced a couple of times just to see exactly how good the sucker could be without guessing and then kicked out for lack of a roll cage. It`s in "My Corvette Photos" on the left.
The vette also has a full length frame vs sub frame.
Got to go heavy duty either way and I have always loved C3 Vettes since I was a kid. To avoid the smog checks in Calif, I could go as late as a 75. Why go only 68-72?
If it's just gonna be a street car,I would not worry about traction either.On the street,boiling them is part of the fun.(We would never race on the street anyway's rite?) It sounds like it's gonna be mean!
I have a 69 Camaro (full DSE setup and 700 flywheel HP motor) and a 68 vette.
As mentioned above, the camaro is much better supported with a variety of high quality pieces (4 links, WHATEVER). If I was going to build just a fast street car, it would be the Camaro.
For what it's worth, the Camaro does get more looks, but not by much.
One other thing for your thoughts, but a twin turbo small block would be a bit more driveable (in terms of less TQ down low) and would require less in terms of traction support. It would still give you as much HP as you wanted and you could spin the motor for days.
Bryan
