Speedo bounce, but only when hot??
Old Aug 11, 2006 | 04:10 PM
72Tornado's Avatar
72Tornado
Default Speedo bounce, but only when hot??
I've been having a very inconsistent speedo bounce problem since I got my car. I pulled the cable, cleaned it thoroughly, and lubricated it very well with cable lube. The problem didn't go away. The needle only bounces when the engine is warm or on a very hot day. When rolling to a stop, it will read 1-2mph as it should and then suddenly bounce to 20, rest back to where it was before, etc. What's going on here?
Old Aug 11, 2006 | 05:58 PM
Bob Onit's Avatar
Bob Onit
I wouls start with replacing the drive gear on the transmission
They are plastic and color coded and not expensive
Old Aug 12, 2006 | 03:19 PM
icanfixitforyou's Avatar
icanfixitforyou
It sounds like the cable is binding in it's housing when it gets hot. The sudden jump to 20 mph is when the bound up cable unloads. I just replaced a speedo cable because it melted against my exhaust pipes, could this also be a source for your problem? The cable is not overly difficult or expensive to replace. I zip tied my new cable away from the exhaust pipes.
To Speedo bounce, but only when hot??
