Valve seals
Old Aug 11, 2006 | 10:11 PM
Amature's Avatar
Amature
Default Valve seals
I have a miss in the 350 engine of our 1970. A few issues have been taken care of but it still persists. I have one plug in particular that keeps fouling. I have been told I have bad valve seals. Is this something that I should have done by itself or should the complete heads be rebuilt? In the past I have heard that if the seals are bad, then the whole engine needs a rebuild. What would be a fair price to have justs the heads done? I'm not taking them off myself. I just don't have the time to do it. The speed-o-meter shows about 97,000 miles. The car received a "Top Flight " award with the previous owner in 1995. I am well aware that this in no way assures me the engine was also rebulit properly with the restoration. Last year the car ran smoothly. This year it really shows the miss when you down shift to make a corner & accelerate to shift back into 4th gear. It also used to run well in 4th gear at 25 or 30 mph. Now it does not. Thanks for the advice in advance. We're starting to feel like were driving a money pit.
Old Aug 11, 2006 | 10:42 PM
Red70vette's Avatar
Red70vette
Needing valve seals does not mean you need a rebuild. If you get some smoke on start up that might mean you need valve seals. If they are not functioning oil will leak down into your cylinders after you trun off the car and burn off when you start it up.
It could foul your plugs and cause a miss but you really need someone who knows Corvettes to check the car out and find out what the cause is. It could be simple or it could be a major repair.
If you don't want to spend the money replace the spark plugs and check that you are getting spark to each plug. It could be as simple as a bad wire or plug that is causing it not to fire and foul.
Old Aug 12, 2006 | 12:03 AM
DMONSVETTE's Avatar
DMONSVETTE
Old Aug 12, 2006 | 08:27 AM
Amature's Avatar
Amature
At this point in time, I have changed plugs three times. I originally did it last fall just because I figured they were old & needed replacing. The car ran fine before I did that. That is when the troubles started. It had AC R45s & I ordered from a catalog since there were some other items that I needed. The ones I received were R43. It seemed to run smooth at first but after 25 miles or so, I could sense a miss. I checked & found the plugs didn't match what I had originaly so I bought some more. I didn't notice the "s" so I bought R45. It still had the miss so I checked the old plugs again & noticed the "S". I now have the R45s plugs installed. I tried a tight 35 thousandths gap and now I'm going to try a loose 35. I also have a new cap & rotor & new plug wires. I just feel with my luck it will turn out to be more.
Old Aug 12, 2006 | 09:52 AM
Paul L's Avatar
Paul L
Have you changed the points and condensor?
Old Aug 12, 2006 | 09:57 AM
fast idle's Avatar
fast idle
a simple compression test will tell if it's seals or if you have a real problem.If compression is good,add a set of wires and cap,also points if you are still running them.
try a gap of .45 thats where mine seems happiest.
Old Aug 12, 2006 | 02:03 PM
Paul L's Avatar
Paul L
I have to disagree with fast idle. Valve stem seals will not affect compression readings. And the 0.045" plug gap is for HEI-equipped cars, not those with points and condensor such as in 1970.
Old Aug 12, 2006 | 02:20 PM
Amature's Avatar
Amature
At this point, I have not tried the points & condensor. I don't know what the previous owner used in the engine but it apparently isn't quite stock. When I first got it I tried to check the timing & was not able to with my timing light. I had the vacuum lined plugged & the timing mark was moving all over. It would not set still so I could see where I was at. I ended up taking it to the Chevy dealer & had them set the timing & points.
Old Aug 12, 2006 | 02:30 PM
Bob Onit's Avatar
Bob Onit
When I bought my 73' the Valve guide seals were in bad shape and the engine only had 2,000 miles on a rebuild.
Problem is that it sat for 11 years.
I talked to a local Vette shop (this guy knows his stuff , very well respected but also very expensive)
He said if you dont want to change the seals right now change the spark plug#.
I took his advice, I switched from AC Delco R45T to R45TS
The plug is a little longer than the T which will keep them from fouling.
Everytime I pull one they look PERFECT.
So it smokes for 15 seconds after its been sitting for half a day or more but it rund like a clock.
Im not sure If I want to go with new guide seals or smaller chamber heads so I havnt done anything about it yet........ that will be the next project, new guide seals or new heads......... Hmmmm... what would you guys do?
Old Aug 12, 2006 | 02:38 PM
Bob Onit's Avatar
Bob Onit
If you couldntget the timing mark standing still then how the hell did the dealer get it to stay put?..Did you ask them?
Something doesnt sound right at all.
I wouldnt blame leaking valve guide seals on lousy performance unless it smokes constantly, and even then, it could be a much deeper issue than seals.
What did the dealer say about the timing problem??????
I would love to know.
Old Aug 12, 2006 | 04:20 PM
Red70vette's Avatar
Red70vette
You really need to get soomeone who knows what they are doing to look at this car. The timing mark shouldn't be jumping all over the place. If the cap and wires were replaced do you have wires crossed? How did it run after the dealer timed it? If it ran good then what was done after that? You are replacing everything but fixing nothing. You have to have someone find out what the problem is.
Old Aug 13, 2006 | 08:00 AM
fast idle's Avatar
fast idle
paul 67,what i meant was,a good compression test would indicate a seal rather than a burnt valve or ring.
If the compression test revealed a low cylender,then he doesn't need to worry about seals,he has bigger problems.
sorry about the wrong info regarding the points,i missed the year of the vehicle.
Old Aug 13, 2006 | 03:44 PM
ajrothm's Avatar
ajrothm
I recently changed the valve seals in both my 71 sb and my dad's 69 BB. Both were smoking on start up and at hot idle. It was pretty often that both of them would start smoking at any given time. Both were fouling plugs. I changed the valve seals with the heads still on the car, takes 3 hrs or so about about $30 for seals and spark plugs. I would try that first, I am sure thats your problem. Put air in the cylinder to hold the valves up.
Both of our cars run well and do not smoke at all, neither has fouled a plug yet either in about 500 miles
Old Aug 13, 2006 | 03:58 PM
Bob Onit's Avatar
Bob Onit
I have a question
I need to remove my Intake manifold to re seal it..Its leaking a little oil so Im guessing its also leaking vacuum?
Anyhow
With the intake removed is there a way to hold the valves up? (I'm trying to picture this in my head)
I dont trust my antique compressor to hold air long enough to do the job
The compressor is 220 and I dont have 220 in the garage nor do I have a couple hundred feet of hose to make it to the garage.
So... where do I stand with the intake manifold removed?
Thanks!
Old Aug 13, 2006 | 04:36 PM
ajrothm's Avatar
ajrothm
removing the intake will not affect the valves since you are not taking off the rocker arms and valve springs.
Old Aug 13, 2006 | 04:59 PM
Bob Onit's Avatar
Bob Onit
Thanks for the reply
I was trying to think if I could grab the pushrod somehow and keep the valve up but I guess that would do just the opposite
Old Aug 13, 2006 | 10:12 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Does the spark plug you're suspecting look different than the other 7 ?
Does the engine consume oil ?
IF the valve seal is bad you'll see the burnt oil on the plug.
Your balancer seems to be slipping, that's likely why your timing mark moves. This seems to be very common, a new balancer is however relatively inexpensive.
Any spark plug listed in the parts store's catalog should be fine. there may be some performance differences but any of these, no matter what brand should be good enough to get the engine running without missing....
It could be as simple as a weak coil.
Before you go to a shop: This is a simple Chevy small block engine, they made gazillios of these. It's not a Corvette specific problem that requires a "Corvette expert" who charges $150/hour.
Old Aug 16, 2006 | 09:04 PM
Amature's Avatar
Amature
I did finally manage to get the car into another garage. In my haste, I had crossed a couple of the new plug wires I installed. That wasn't the big problem though. They found the distributor was shot. When they tried to get at the points, the plate was moving. They said a lot of people like to use chassis grease in the distributor when they rebuild them. It tends to get sticky & grabs enough that the bearing spins in the housing. They rebuilt the distributor , put in new points & plugs & retimmed it. It runs a lot better now. I still think I have an oil fouling problem though. I will check that Friday. They didn't see that since I had removed the deposits from the worst plug.
Old Aug 16, 2006 | 09:23 PM
Bob Onit's Avatar
Bob Onit
I did finally manage to get the car into another garage. They found the distributor was shot.
Time to back to the dealer and ask them how they timed an engine with a "shot" distributor... In my opinion, Somebody is lying to you
To Valve seals
