Power steering... An ODD quirk...
Old Aug 13, 2006 | 04:19 PM
breathial's Avatar
breathial
Default Power steering... An ODD quirk...
In the quest to get my Vette on the road, I just installed a new PS pump, using aftermarket brackets (from EBay).
After filling the pump with fluid, I cycled the front wheels lock to lock, and then topped off the reservoir. But something interesting- at idle, everything appears normal. But when I blip the throttle, the wheel actually pulls anywhere between 1/8 and 1/4 of a full rotation of the wheel.
WTF?
Any ideas on how to cure this... "problem?" There are no leaks, but the PS has not been hooked up for VERY long time- Bubba had taken the original 350 out, put in a 454, and just ran it without the PS hooked up...
Any input would be greatly appreciated- I've never seen this sort of thing before... BTW, it's a '74 with a 427BBC, TKO-600, idles about 800 RPM.
Old Aug 13, 2006 | 04:36 PM
chris75stingray's Avatar
chris75stingray
i've heard if you have the hoses switched around it will turn the wheel by itself.
Old Aug 13, 2006 | 04:41 PM
breathial's Avatar
breathial
the hoses at the cylinder were still intact, just held up (with a coat-hanger) out of the way... So it was easy to hook up, as the high-pressure line could only go to the threaded hook-up, and the return line to the nipple (with a hose-clamp)...
I tend to doubt that this is it... Any other ideas....?
Old Aug 13, 2006 | 04:45 PM
chris73cpe's Avatar
chris73cpe
you can try balancing the valve too, jim shea has some good papers on that
Old Aug 13, 2006 | 04:55 PM
cchristo's Avatar
cchristo
Sounds like it's just a little off balance.
Very simple to check and adjust.
Old Aug 13, 2006 | 11:21 PM
682XLR8's Avatar
682XLR8
Just a control valve not balanced. If the hoses were reversed, the wheel would jerk back and forth. Found this out the hard way
Old Aug 15, 2006 | 02:18 AM
breathial's Avatar
breathial
Thanks, everybody, for the reply.
All fixed, used the papers..... AND used those papers to align the car.
Took it for a drive tonight- the first time it's been on the road in 3 years!!!!
It was cool... though I need to solve the overheating issues...
To Power steering... An ODD quirk...
