Convert. Deck Lid Hinge Removal ??
Old Aug 15, 2006 | 09:39 PM
GOLDEN65CPE's Avatar
GOLDEN65CPE
Default Convert. Deck Lid Hinge Removal ??
Trying to remove the rear deck hinges and I'm stuck. I removed the lower hinge bolt from the floor Reinf without a problem. Of the two upper bolts, I removed the inside one easily but I cannot get a 1/2 inch open end wrench, box wrench, socket wrench, or anything on the outside bolt. Its only a two finger space and very hard to get anything on the bolt head. I dont have a clue as to how they did it in the factory. I have to get the hinge off as the Reinf at bottom is rotted and will be replaced. Any hints on a special tool or any ideas?
Old Aug 15, 2006 | 09:50 PM
JustForFun's Avatar
JustForFun
try a crows foot wrench. if it was me ide drill a hole from back side and go in fromunder veh while having someone guide socket from top. use a rubber body plug to reseal hole.
Old Aug 15, 2006 | 10:05 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
a search would have found this:
http://forums.corvetteforum.com/show....php?t=1467680
from only two days ago!
Old Aug 16, 2006 | 06:59 AM
GOLDEN65CPE
Thanks for the tip, I didn't realize the problem had been previously posted on the forum. I did attempt a search before I posted by searching for "hinge" and found nothing. I guess I should have searched "hinges" Oh well!
Old Aug 16, 2006 | 08:47 AM
RPOZ4Z's Avatar
RPOZ4Z
I think the "best" solution is to go in from the back, and use those body seal plugs to seal the holes.
Old Aug 16, 2006 | 09:03 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by GOLDEN65CPE
...I dont have a clue as to how they did it in the factory...
Hinges were installed before the rear panel was bonded.
To Convert. Deck Lid Hinge Removal ??
