Speedometer gear replacement?
Old Aug 16, 2006 | 12:31 AM
wxw116's Avatar
wxw116
Default Speedometer gear replacement?
Hey guys,
Im trying to find a part # in my paragon catalog to replace the speedometer GEAR, but Im not having any luck.
I bought the gear fitting with the O-ring (part #7188k at paragon), but it turns out that wasnt it.
The piece I need is shown on the diagram on page 18, looks like it slides into the gear fitting and is shaped like a screw with gear-teeth on top of it, but I can't for the life of me figure out what it's called or where to buy it.
Help appreacited.
Old Aug 16, 2006 | 01:57 AM
...Roger...'s Avatar
...Roger...
Originally Posted by wxw116
Hey guys,
Help appreacited.
Go to Ecklers site and type in the search bar speedo gear-what you want is the driven gear-different colors for diff. number of teeth
Old Aug 16, 2006 | 02:04 AM
wxw116's Avatar
wxw116
Default thanks
Now how the heck do I know which one I need?
Dont have the old one anymore.
car is a 4spd 1974 454 vert.
For the record, the gear fitting @ ecklers is $13 and @ paragon it's $23. Oops.
Old Aug 16, 2006 | 02:53 AM
tfi racing's Avatar
tfi racing
Why not try your local transmission shop?They probably have a box or two of them sitting around and may even give away one or two if you ask nicely enough!If you are lucky you may run into one of the old timer's that has a clue and could recommend a gear that should work.
Old Aug 16, 2006 | 09:01 AM
...Roger...
To be exact could be tricky-rear ratio-tire size-if you could do what TFI said and ask if you can leave deposit and take a few and return what you dont use would be the best-but if not tell me tire size and rear end and I will look in the book and "try" to recommend one.Maybe if when you call Ecklers they might take your info and come up with one.
Old Aug 16, 2006 | 02:10 PM
wxw116's Avatar
wxw116
Default thanks for the help so far guys
The car is totally stock, so I think the right numbers are on the plate on the shifter console:
454, 395 lbs. ft of torque, 8.25:1 ratio.
Tires are firestone wide ovals, g70-15
That the info you needed?
Thanks again all.
Old Aug 16, 2006 | 03:10 PM
BB68Vett's Avatar
BB68Vett
There is a website that has a software utility that will tell you how many teeth your driven gear needs to be. I can't remember the name of it but I believe you need the number of teeth on the drive gear (the one inside the tranny that meshes with the plastic one), as well as the rear end ratio.
Old Aug 16, 2006 | 07:59 PM
...Roger...
Thanks again all.
Also need rear end ratio
Old Aug 16, 2006 | 09:07 PM
surgn's Avatar
surgn
I'm actually in the process of replacing mine this weekend- going to get the piece from a chevy dealership- they will order and have next day or you can get lucky and they'll have in stock- yeah, that's me...$5 to $11 for what you need-depending on the dealership. And you are saying it right. Hope this helps.
Old Aug 17, 2006 | 04:41 AM
tfi racing's Avatar
tfi racing
I know I saw it somewhere,my 73 assembly manual has a chart for drive and driven gears.The drive gear(on the output shaft of the trans) should have 8 teeth(manual trans) and the driven gear will vary on the diff. ratio.If you can tell me what rear gear you have,I can tell you what the chart says.
Old Aug 17, 2006 | 02:49 PM
wxw116's Avatar
wxw116
Default got it
Figured I would try my luck digging through some shop trash lo and behold it was still there, thank goodness.
Turns out it was white w/ 19 teeth.
Thanks all for the help.
Old Aug 17, 2006 | 04:42 PM
Blown69's Avatar
Blown69
I need one also. I wonder if the drive gear is color coded to match color of gear? I dont have to old one.
Old Aug 17, 2006 | 06:46 PM
...Roger...
No -no matching color coding.
To Speedometer gear replacement?
