Air cleaner drop base?
Old Aug 19, 2006 | 12:21 PM
CoolKars's Avatar
CoolKars
Default Air cleaner drop base?
There are two air cleaner drop bases available, Corvette Central part #'s 152088 - L88/ LT1 & 153022 Open type. The only difference I see in the two is the postioning of the vent tube. How does this affect the fit with different carbs.
I am using a 2101 Performer intake & Q-jet, which base will work with the Q-jet & will it work with a Holley or Demon.
Old Aug 19, 2006 | 03:48 PM
Matt O's Avatar
Matt O
I have a 69 350 with the origional drop base. Car had a Q-jet, changed that to a Holley years back and now to a Road Demon. Fit all three with a minor mod on top. By the way the Road Demon runs the best....
Old Aug 19, 2006 | 05:22 PM
CoolKars's Avatar
CoolKars
Thanks for info.
Are you using a stock intake, if not which intake and can you fit a 3" filter element with stock hood.
To Air cleaner drop base?
