79 Power window problem
Old Aug 19, 2006 | 04:55 PM
caseybandy7777's Avatar
caseybandy7777
Default 79 Power window problem
Window went down but will not go up. there is power getting to the motors. I thought it was odd that both would stop working at the same time. any ideas
Old Aug 19, 2006 | 06:22 PM
VET4LES's Avatar
VET4LES
Sounds like a fuse but the C3 group might have a better idea.
Old Aug 19, 2006 | 08:47 PM
redcar1979's Avatar
redcar1979
The power or voltage must make a round trip. Must have a ground to complete the circuit. Have you looked into this?
Old Aug 19, 2006 | 08:52 PM
c3dreamer's Avatar
c3dreamer
check:
1. if weather stips force glass to prevent up movement
2. check switches condition
3. check wiring and for loose grounds
4. check for loose connections
To 79 Power window problem
