A-Arm Bushing Removal?
Old Aug 19, 2006 | 05:50 PM
Emeightch's Avatar
Emeightch
Default A-Arm Bushing Removal?
Can anyone enlighten me on how the Frt A-Arm Bushings and the attachment rods are taken apart?
Old Aug 19, 2006 | 06:23 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I just pried the shells out with a cold chisel and a hammer. The upper cross shafts can come out with the shells in place. The lowers are a bit more complicated - the outer shells pin the crossshaft into the arm.
Old Aug 20, 2006 | 05:19 PM
seventysixvette's Avatar
seventysixvette
I just rebuilt a set of a-arms I got off e-bay. Just drill the rubber out of the bushings. I chucked my a-arms in the vise. Hold them by the shaft, not the body of the arm. Drill both ends out. After a certain point, you can work the arms back and forth, and the old rubber will just crumble and fall out. The outer shells are in the a-arm, and are easily driven out with a SMALL ball peen hammer. the inners are on the shaft. If you look close, you'll see where they are split. Just take a small slotted screwdriver and drive it into the slot. A tiny bit of WD-40, and it'll slide right off the shaft end. You don't need a press or anything fancy to change out your ball joints and bushings, and really, you don't even need a lot of time. I did all four of mine in about 2 hours. That was a lot of jawing with a few of my friends who were over just killing time.
Hope this helps.....John
Old Aug 20, 2006 | 08:46 PM
BenUK's Avatar
BenUK
OK, I got another opinion!
I burnt mine out.
Get a decent-sized blowtorch and heat the outer shell of the bushing. Eventually it'll get so hot that the rubber expands and forces itself out of the bush, leaving it all charred and loose. Worked a treat. The metal gets nowhere near red-hot.
Obviously this screws up the paint, so if you're not planning to re-paint the A-arms then you need to use one of the more time-consuming mechanical methods.
Old Aug 20, 2006 | 10:03 PM
MsVetteMan's Avatar
MsVetteMan
For the lower a arm, put it in a vice clamed near the bushing. Take a big screwdriver or chisel and beat in the NON-LIPPED side. Next beat it downward, and it will pop out. Nothing to it. Just did it.
Old Aug 20, 2006 | 10:32 PM
bertmeister's Avatar
bertmeister
I burnt mine out.
Old Aug 20, 2006 | 11:06 PM
MsVetteMan's Avatar
MsVetteMan
Uhhh......I can take one out in about 2 minutes.
Old Aug 20, 2006 | 11:40 PM
big_G's Avatar
big_G
Me and my air chisel can do each one in 10 seconds or less...HA!
Old Aug 20, 2006 | 11:44 PM
MsVetteMan's Avatar
MsVetteMan
I have got to get me some air tools!!
Old Aug 21, 2006 | 03:31 AM
BenUK's Avatar
BenUK
I'm really curious to understand what you mean with your method. I've done one side using the flame method and am waiting to do the other. (My wife gave birth to our first child yesterday... Vette projects have to wait, apparently ) I'm certainly interested in finding a less messy method.
What do you mean about hitting the non-lipped side before you hit it downwards? Do you just beat on the bushing first before you try to hit it out of the A-arm?
I don't have a vise to clamp the A-arm in. I guess this is going to make things pretty much impossible?
Old Aug 21, 2006 | 10:22 AM
MsVetteMan's Avatar
MsVetteMan
First I removed the poly bushing. Then I took a big screw driver and started collasping the end inwards. Then took the screwdriver and hammer and beat it downward until it popped out. This would be very difficult to do with out a vise or something to hold the a arm steady.
Old Aug 21, 2006 | 10:52 AM
BenUK's Avatar
BenUK
Ah-hah - I think poly bushes are different, in that the flexible material isn't bonded tightly to the metal bits. Rubber bushes are all glued together, so you can't knock the outer shell out without separating it from the inner shell. Hence the heat to destroy the rubber first.
...I think.
Old Aug 21, 2006 | 11:23 AM
NHvette's Avatar
NHvette
...I think.
Ben's right about that ... rubber can cause much more trouble.
Picking up a few tips from Lar's paper ... and doing oodles of them since, Ive learned:
A little heat with a propane torch on the arm will expand the arm enough
to let the shell come out easier. I no longer remove the rubber at all.
After heating (cross shaft held in vice), use your air chisel or cold chisel
to push the inner edge of the inner sleeve enought to see it is not
frozen to the shaft. Next, use the air chisel to work the inner edge
of the outer shell ... then pry with the air chisel under the outer lip
of the outer shell. Work around and on opposite sides. Use a little more
heat to make it easier. Note that I also have made a special bit for
my air chisel. Starting with a wide chisel bit, use your grinder to turn the
flat cutting edge to a crescent shaped curve. Then, make the crescent
shaped edge thin but not sharp. Round it over to be blunt. You don't
want to cut through the shells, just push and pry them.
I hope this helps. Every time I do another set, I learn a new trick.
Old Aug 21, 2006 | 12:09 PM
Emeightch's Avatar
Emeightch
Thanks Guys! I have a pretty good idea. I think I'll try the torch method first. The rubber bushings look like they are ready to turn to dust anyways.
Old Aug 21, 2006 | 05:03 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I just wedged the arm against something soild, then used a cold chisel and hammer to hit the lip of the outer bushing shell. Moving around the lip allows the shell to come out straight. I think I took about 20 minutes per arm, and I didn't do anything to the old rubber bushings inside the shells. If I had had an air chisel it would have been much faster.
MSVetteMan, you're making waaaaay too much work for yourself.
Old Aug 21, 2006 | 08:19 PM
gonzo14's Avatar
gonzo14
Blow that thing away fast with an air chisel, job done in no time, The "big G" is thinkin' straight, he knows the deal --"gettin' it done and drinkin' beer with the ladies"--- while MsVetteman is drinkin' gallons of Pepto.
Gonzo
Old Aug 21, 2006 | 09:27 PM
big_G's Avatar
big_G
Yep, gotta have priorities...
To A-Arm Bushing Removal?
Old Aug 21, 2006 | 11:21 PM
MsVetteMan's Avatar
MsVetteMan
Easy now boys. Easy. Hey, I got the upper control arms off tonight, and you don't have to take the fan shroud off. Just got a crow bar and pried one side off, then twisted it upwards, and pried the other side off. Just enough flex in the shroud to get them out.
Now the upper bushings came out pretty easy as well, and I just skipped the screwdriver part and went straight to the BFH!! Bent them in a bit, and hammered them out in 5 seconds............WINNER!! Actually it took a few minutes, but they busted right out.
The rubber shouldn't make a difference, just get a BFH!!
Old Aug 22, 2006 | 09:01 AM
gonzo14's Avatar
gonzo14
My mistake, you got it done faster than I thought...good Job Vetteman. NOW GRAB A BEER MAN!!
P.S. INVEST IN AN AIR CHISEL
Gonzo
Old Aug 22, 2006 | 10:20 AM
Duke94's Avatar
Duke94
Yes, air chisel. Buzzz and it's out.
