headlight vac relay rebuild.
Old Aug 20, 2006 | 08:37 AM
JustForFun's Avatar
JustForFun
Default headlight vac relay rebuild.
has anyone rebuilt these themselves with success. I cant remember how they are assembled and if the can be rebuilt. Ideas?
Old Aug 20, 2006 | 11:33 AM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
The "buckets" are easy to rebuild with a kit from ZIP...about 19 bucks each. Each bucket has 3 parts....2 rubber seals and a metal retainer.
The smaller relay valve(s)....I am not sure it can be rebuilt. I have had luck with spraying the rubber seals in the relays with lubricant....it causes the dried out seals to swell and they stop leaking vacuum.
Give it a try.
Old Aug 20, 2006 | 01:30 PM
mdj21's Avatar
mdj21
this guy has a procedure for rebuilding relays.....
http://www.corvette-101.com/
To headlight vac relay rebuild.
