73 454 engine labels
Old Aug 20, 2006 | 05:43 PM
Ran-D's Avatar
Ran-D
Default 73 454 engine labels
Does anyone know the correct location for '73 454 engine labels?
The red one (hard tp read in pic) says Delco Remy on the left and Ignition Coil for Transistor Ignition.
Here is the link to the picture. For some reason I can't add it to the post.
http://community.webshots.com/photo/...7542063dxERos#
Old Aug 20, 2006 | 10:19 PM
trw's Avatar
trw
The "Keep your GM" label is for the drivers side of the air cleaner base. About midway back.
The "Frigidaire" is for the top of the AC compressor.
I think Harrison is for the VIR valve and you do not have a transistor ignition.
Hope this helps.
Terry
Old Aug 20, 2006 | 11:58 PM
chris73cpe's Avatar
chris73cpe
fridgidare and harrison labels(label above harrison is a 134a retrofit label, not stock)
keep your gm car all gm label(right next to non-gm K&N sticker )
My ignition coil is just black with no labels, so I can't help you on that one
Old Aug 21, 2006 | 12:31 AM
Ran-D's Avatar
Ran-D
Thanks guys, got them all located.
To 73 454 engine labels
