how many teeth?
Old Aug 20, 2006 | 07:29 PM
greyghost79's Avatar
greyghost79
Default how many teeth?
starters for chevy's come in 153 and 168 tooth versions. am i correct that all small blocks are 168 tooth (79 L82 350)??? and big blocks are all 153?
thanks for the info.
Old Aug 21, 2006 | 02:34 PM
VettePower's Avatar
VettePower
Good Question. Anyone know?
Old Aug 21, 2006 | 06:04 PM
Jclgodale3's Avatar
Jclgodale3
Same tooth count on the starter for both, I believe. Just different mounting points.
Old Aug 21, 2006 | 06:44 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Some small blocks are 153, others are 168. I don't know about big blocks.
Old Aug 21, 2006 | 06:53 PM
ESC3's Avatar
ESC3
Most small block are 153,not sure which used 168,maybe the 400's.
Old Aug 21, 2006 | 06:58 PM
BobzVette's Avatar
BobzVette
Don't know about the number teeth on the starters but some flywheels had different number of teeth. For instance, GM casting #3973458 is a 14", 168 tooth flywheel for internally balanced engines, both small block and big block. However, ALL Corvette 327 cid engines used a 12-3/4", 153 tooth flywheel.
Hope this helps.
Old Aug 21, 2006 | 08:33 PM
greyghost79
Old Aug 21, 2006 | 08:42 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
My L48 has a 168 tooth flexplate.
To how many teeth?
