Steering Wheel Position?
Old Aug 26, 2006 | 09:52 AM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
Default Steering Wheel Position?
First off, my 68 has been completely taken apart for a couple of years so I can't remember how it was. I am in the process of putting the steering gear, pedal assembly and column back in the car.
Here is what I am finding, the centerline of the seat and the centerline of the steering gear are not lined up. So, I looked at some C3's and found that the steering column is not straight with the centerline of the car and neither is the steering wheel. I assume GM did this to center the wheel on the seat.
Anyone else notice this? Do you get used to it? Seems weird.
Old Aug 26, 2006 | 10:10 AM
Duke94's Avatar
Duke94
Yes, the column is not parallel with the frame.
Old Aug 26, 2006 | 11:42 AM
BBShark's Avatar
BBShark
Thanks. As I said, I have observed this also. What I would really like to know is, do you get used to this? To me it seems weird.
Old Aug 26, 2006 | 01:02 PM
Duke94's Avatar
Duke94
Actually I never noticed it until I pulled the column out. There's quit a few cars like this. They need to bolt the steering gear box to the frame which never seems to line up with the center of the seat. I guess they could have used a couple u-joints and a connecting shaft, but that cost $$$.
Old Aug 26, 2006 | 04:44 PM
StickShiftCorvette's Avatar
StickShiftCorvette
I had noticed it, but after 145,000 miles of fun, I am quite used to it.....
Old Aug 26, 2006 | 06:19 PM
ksbunting's Avatar
ksbunting
BBSHARK,
Yes you get used to it.
I have had my 68 since 1972 and I am used to it. No problem.
Kurt
Old Aug 26, 2006 | 07:24 PM
mkflanagan's Avatar
mkflanagan
man am i glad to know this is normal,I thought my '76 frame was screwed up or something.
To Steering Wheel Position?
