Well I did it.....
Old Aug 26, 2006 | 11:25 AM
JustForFun's Avatar
JustForFun
Default Well I did it.....
Finally got around this morning to installing my side pipes. Not sure if my method suits everyone, but I bolted them diredctly to the frame....How you might ask. I drilled a hole for the bolt, went under car with a drill and die grinder and made me a wrench slot. put bolt on side pipe, put thru hole, attached nut, and tightened thru slot. WORKS GREAT. those who have had to install sidepipes with the crap brackets they give you will understand. notched the side covers and here we are. The result is that they dont sit low. they arent connected and functional yet, but soon as i can get to store and get some exhaust parts and get my C5 off my lift, they will be hooked up.
Old Aug 26, 2006 | 11:35 AM
LittleJake's Avatar
LittleJake
They look great! I like them up higher and off the ground. Nice job!
Old Aug 26, 2006 | 11:39 AM
JustForFun's Avatar
JustForFun
its your glass that completed it
man you have NO IDEA, how easier that door glass had made my corvette life!
Old Aug 26, 2006 | 12:30 PM
Vet76te's Avatar
Vet76te
They look good,...but I have a question. If you bolted them directly to the frame, how will you compensate for the movement of the engine? The headers are bolted directly to the engine and the engine has movement as it is accelerated and decelerated. If the pipes are bolted directly to the frame, how will this minor movement be absorbed?
A few years ago, I installed new exhaust on my MGA. I bolted a hard bracket from the down pipe directly to the frame. The car had a minor vibration, and after a few hundred miles driving, it broke the bracket. I ended up having to run the correct mounts with their weak brackets and rubber absorbers.
Just curious.
Old Aug 26, 2006 | 12:39 PM
Bangkok Dean's Avatar
Bangkok Dean
Side pipes rock
Old Aug 26, 2006 | 12:47 PM
TheMongoose's Avatar
TheMongoose
sweet!
How about a few pics of how you mounted them? I was figuring on doing something similar for now because I don't have enough money to put the headers on and get all the U and J pipes to mount everything up. I thought the setup they provided for the pipeslooked like crap too. Only part I want to keep is the rubber isolators.
Old Aug 26, 2006 | 01:45 PM
JustForFun's Avatar
JustForFun
i sandwiched 1 rubber isulator between frame and sidepipe. that seems to be enough cushion to allow some, but very little movement. Matter of fact i just got back from muffler shop. guy charged me 60 bucks to connect em to exhaust. he made couple pieces, removed the old exhaust, supplied all parts and connect everything.....
Love the way they sound
Old Aug 26, 2006 | 02:06 PM
C3Racing's Avatar
C3Racing
St. Jude Donor '07-'08
Love the sidepipes plus the convertable mod.
Old Aug 26, 2006 | 05:08 PM
JustForFun's Avatar
JustForFun
well she`s heard em.....and they passed the "she test"
Course...she hasnt burned her leg yet
Old Aug 26, 2006 | 06:08 PM
chevy69's Avatar
chevy69
St. Jude Donor '08
Looks great
Old Aug 26, 2006 | 06:13 PM
sperkins's Avatar
sperkins
Looks good. Any mufflers?
Oh - Don't forget to update your Avatar.
Old Aug 26, 2006 | 06:16 PM
sperkins's Avatar
sperkins
Did you go with the Summit kit you posted about a few weeks ago?
Total cost and link to item please.
Old Aug 26, 2006 | 09:49 PM
JustForFun's Avatar
JustForFun
http://store.summitracing.com/partde...0&autoview=sku
plus have a $20.00 off coupon.
Old Aug 26, 2006 | 10:11 PM
Billysvette's Avatar
Billysvette
Originally Posted by JustForFun
I dont know too much about the side pipes,but,i looked at your order and the pic of the patriot pipes does not have a header flange that bolts to the heads.what do you do to finish the headers off?The pic looks like half of the lower part of the headers.
To Well I did it.....
