Drilling out rivets on rotors?
Old Aug 26, 2006 | 05:30 PM
nihil's Avatar
nihil
Default Drilling out rivets on rotors?
I was planning on pulling out the suspension today but I am stuck. The GM shop manual says to drill out the rivets (I assume the rivets are the five rivets between the wheel studs). I tried some drill bits with an electric power drill, but no luck. What kind of a drill bit do I need, and what is the optimal width?
When putting the rotors back on, how are the rivets re-inserted? Do you hammer them in? Are those the only thing holding the wheel onto the car?
Old Aug 26, 2006 | 05:52 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Don't remember for sure....been a while. Will the disk and hub come off as one piece, if you remove the outer bearing. ??? Only remove the rivets IF you need to get the disk turned for a brake job.
Somebody help us out here!
I am a bit puzzled with my 74...."appears" to have 106,654 miles, but the factory rivets are still there. Disks are true and "like new". Odo shows 06654.00 miles. Don't make any sense to me.
Old Aug 26, 2006 | 05:59 PM
BigBlockk's Avatar
BigBlockk
I had to use cardide bits. Monay, money, money. You could use an angle grinder and grind the heads off. Don't worry about putting the rivits back in.
BigBlockk
Later.....
Old Aug 26, 2006 | 06:16 PM
ksbunting's Avatar
ksbunting
After drilling out the rivets, the lug nuts hold the rotor when you reinstall the wheel. You don't have to use new rivets as the lug nuts will do the job.
Kurt
Old Aug 26, 2006 | 06:28 PM
nihil's Avatar
nihil
Ahh, thanks for the info. Is it standard not to replace the rivets?
Old Aug 26, 2006 | 06:31 PM
70 LS1's Avatar
70 LS1
Not unless you are doing a NCRS restoration.
ksbunting's Avatar
ksbunting
From what I have read, many do not replace the rivets.
I think it is fairly common to leave them out and just let the lug nuts hold the wheel.
My 68 still has the rivets in place.
Kurt
Old Aug 26, 2006 | 06:33 PM
Gordonm's Avatar
Gordonm
I did it with a set of cheapo drill bits. I did it in 3 sizes though. Start out small then increase to a larger one. Slower speed with some cutting oil worked well. I had the fronts in a drill press also. Take off the hub assembly and put it in the drill press. Much easier.
Old Aug 26, 2006 | 06:39 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Regular 'el cheapo' drill bits will get the job done. Use a centerpunch and drill a small hole first. You don't have to drill all the way thru, as soon as you drilled the rivet's head off you can punch the rest out. Use oil to cool the drill bit.....
You may find shims between the rotor and axle, these are to align the rotor (to reduce runout)
Old Aug 26, 2006 | 07:07 PM
1982CorvetteDude's Avatar
1982CorvetteDude
Since i was replacing my rotors anyways I used a angle grinder to grind the rivets about 1/16" into the rotors to break the rivet lip, then I used my air impact hammer gun and a pointy attachment to knock the rivet out from behind.
I tried the "drill bit" method at first and this was WAY easier for me.
Old Aug 26, 2006 | 07:11 PM
jake1's Avatar
jake1
I just drilled out mine yesterday and it's not to bad. Just use a 1/4 size bit about 3/4" in then use alittle larger bit to break the rivet cap, then bang them out a 1/4 size punch.
Old Aug 26, 2006 | 07:43 PM
73jst4fun's Avatar
73jst4fun
The rivets were only installed on the assembly line to speed up the installation process, you really don't need them...
Old Aug 27, 2006 | 11:05 PM
nihil's Avatar
nihil
Well, I drilled the center out of all five rivets and couldn't pop any of them out.
However, I discovered after taking the time to drill every rivet, there was this thing called the wheel hub and bearing, and after removing them in about five minutes the rotor slipped right out. Live and learn I guess. Rebuilding everything with no prior automotive repair experience has led to some interesting mistakes and a few thrown wrenches.
After looking at the rotors... what in the heck do the rivets accomplish? They don't seem to have any functional value as they don't appear to attach to anything.
Old Aug 27, 2006 | 11:12 PM
chris73cpe's Avatar
chris73cpe
the rivets hold the rotor to the hub with the tire off. they used them in the factory so they could flip the frame over on the line without the rotors falling off(so I've heard). This also makes it easier to set the runout on the rotors-true up assembly instead of trueing both hub and rotor seperate.
Old Aug 27, 2006 | 11:19 PM
nihil's Avatar
nihil
Weird. Within the hub there was a large nut that held in the rotor bearing. A cotter pin was fitted through the nut. Once the nut and bearing were removed, the rotor slipped off. The rivets were connected to absolutely nothing and simply went through the rotor thickness. The rivets I was looking at were on the rotor itself, between the lug nut bolts.
I couldn't identify anything holding the wheel on other than the nut and bearing. Perhaps what I was thinking were "the" rivets were not there, and the rotor has been replaced some time ago?
Old Aug 27, 2006 | 11:41 PM
...Roger...'s Avatar
...Roger...
Your working on the front-thought you were talking about the rear.The rotors were riveted frt and rear because they were assemblys.The frt hubs and rear spindle flanges were not always 0 runout.The rotors were turned while riveted to the hubs or spindle.When you brake them apart and put on a new rotor you have to face the rotor if not lower than .005 runout-thats easy on the front-not on the rear.Once the large nut on the spindle has been torqued to spec the center for lathe turning is tweaked.
Old Aug 28, 2006 | 12:34 AM
70 LS1's Avatar
70 LS1
You are talking about the rotor and hub together. Sometimes it is needed to separate the two as most replacement and all aftermarket rotors come without a hub. Other disc brake cars of the era used an integral hub and rotor in one instead of two pieces riveted together.
Here is a picture that shows the rivets for everyone.
Here is a front hub minus rotor and studs. You can see where the rivets attach.
And here is a rear hub minus rotor.
Hope this helps clear everything up.
To Drilling out rivets on rotors?
Old Aug 28, 2006 | 07:56 AM
fotyfobravo
Scroll up and see post # 2.........
Old Aug 28, 2006 | 08:49 AM
nihil's Avatar
nihil
AHA! The pictures show it very clearly now. I was thinking the of the rotor and hub as one solid piece. Now I see what part of the rotor the hub actually is.
Old Aug 28, 2006 | 12:36 PM
Mike Ward's Avatar
Mike Ward
NCRS couldn't care less about the rivets, the wheels are not removed during judging.
