engine help!
Old Aug 27, 2006 | 10:04 PM
tecjr's Avatar
tecjr
7th Gear
Default engine help!
We have a 68 vette convertible with an engine which is not original. How do we find out what it originally had for an engine? We are restoring it and i have no idea of what was in it how do i find out?
Old Aug 27, 2006 | 10:10 PM
dgruenke's Avatar
dgruenke
Small block was 327 (standard 300hp; optional 350); big block was 427 (standard 390; optional 435) The big block 435 was with the tri-power carburetion. There was also the L88 big block, but you would know if you had one of those in it originally.
Old Aug 27, 2006 | 11:56 PM
sperkins's Avatar
sperkins
I don't think there is a way to know which option it came with unless you still have the tank sticker. You could check to see if it has a larger radiator. If it is original, it would indicate a big block. Chances are it was a small block, but it going to be really hard to tell unless you can locate the build sheet.
Anyone else?
Old Aug 28, 2006 | 10:50 AM
tecjr's Avatar
tecjr
7th Gear
on the hood it has the holes for what we think might be the 427 emblem
Old Aug 28, 2006 | 11:05 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Anyone else?
look at the radiator,
2.5 in half shalfts are SB usually unless ordered HD,
the u joint for BB had caps, vs straps for SB
sb hood vs BB hood
heater core box config
rear sway bar for BB ????
anyone else?
Old Aug 28, 2006 | 12:42 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...You could check to see if it has a larger radiator. If it is original, it would indicate a big block....
Can't go by radiator alone. Smallblock cars with automatic transmissions got the big four-row radiators used with the big block cars.
I agree. Without documentation from previous owners or the tank sticker, you probably won't be able to determine conclusively how she was equipped when she left St. Louis.
Before you drop the tank looking for the sticker, remember it's been almost forty years since the car left St. Louis. If there's anything still there, it's likely to be illegible.
Welcome to the one-year-only '68 Owner's Club. We're all a little bit crazy.
Old Aug 28, 2006 | 08:56 PM
Sayfoo's Avatar
Sayfoo
I believe that big block cars have cap retainers with french locks on the rear end u-joints and small block cars have u-bolt type retainers. This is generally true, buy high performance small blocks may have the cap type retainers also.
Old Sep 4, 2006 | 09:05 PM
tecjr's Avatar
tecjr
7th Gear
Thanks. We dropped the tank today - a few scraps but the rest was long gone.
The hood looks like a BB hood except emblems are gone.
Does a tach. showing a 5400 rpm redline offer any clues?
To engine help!
