Is it a myth or fact,that if you run 10" or more rims on the back of our cars that it puts more stress on our outer bearings and it will cause bearing failure faster.
If your rear bearings are in the same location as stock and you expand the width of the wheel both inward and outward, there shouldn't be any difference. For example, if you use the offset trailing arms, the location of the rear bearings remains the same, but a 10 inch wheel can be used. The backspacing to keep the wheel in the same location would be 5-1/2 inch. This is 1 inch wider to the inside - add 1 inch to the outside, which is a total of 2 inches. Add this to stock 8 inch wheels and you get your 10 inches...no bearing changes...
It's all about the backspacing ... Think about that really stupid look that some imports used a few years back. They would run a 6" wheel, but it was ALL outside of the wheelwell (and bearings). That has to be hard on the car ... Besides just looking stupid.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
So my answer is...it depends...
5-1/2" ? , I though our stock 8 in. wheels had 4 " backspacing, no ? I better expand this, so if the stock wheel was 4 " backspacing then you add an in on each side for 10" wheels you would have 5 in. backspacing on the 10" rim ?
In the 60's and 70's the VW guys would reverse the stock rear rims--that is just take them off and rotate them 180 deg. That changed the backspace dramatically. Rear track increased by maybe 4". Everyone said that it was bad for the bearings, and probably was, but I don't remember a rash of rear wheel bearing failures. So, probably not the ideal suituation, but, MAYBE, not a problem.
Seems to me you need to factor in other things like backspacing and camber to determine if there is additional stress on the bearing, a blanket 'it creates additonal stress' seems wrong to me.
ie, if you run rims 2" wider than stock with 0 camber there is only additonal stress when the axle travels down, if you run it on a smooth highway then the stress is the same; but if you run postive camber with the same set up then the bearing would be stressed since you are moving the outer most contact point out 2 inches
I was thinking 4-1/2 BS for stock, but you're probably right. I was going from memory...
The way you said it is how it works, assuming that the original offset is 0. I can't remember what the stock offset is though...I went through all this when I was picking out my wheels, then I lost my calcs...
A little offset is apparnetly ok. My Camaros have stock 7" rallies with 4.25" backspace. Our Vette wheels were centered over the bearings,..8" inch wheel, 4" BS.
