rattle can primer
Old Aug 29, 2006 | 03:36 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Default rattle can primer
I'm using rattle can primer on a few areas on the hood and on the bumper seams (bumpers glassed in). I'm using the primer so I can see high and low spots when I'm sanding.
Do I have to remove this primer completely with f.e. thinner or stripper before I shoot the "real" primer ?
Old Aug 29, 2006 | 03:40 PM
VettePower's Avatar
VettePower
Excellent way of doing it. And no you do not have to totally remove it before you primer the whole car. Just lightly sand over it.
Old Aug 29, 2006 | 03:49 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I guess it's time to post photos of the progress....
Old Aug 29, 2006 | 04:34 PM
70 LS1's Avatar
70 LS1
I did the same thing then took the hood to a paint shop. They told me the rattle primer had to be stripped off first and wouldn't paint over it.
Old Aug 29, 2006 | 04:46 PM
NHvette's Avatar
NHvette
My understanding (wrestling with same issues) is that most paint
products are OK to paint over, if SEALED. You need to cover the
old paint(s) with a sealer, like a good 2-part epoxy primer. You want to
make sure that old stuff doesn't bleed through to new paint. Seal it.
I also have some areas I want to spot prime, like the sides of the doors, etc.
I think I'm gonna order up some nice epoxy primer and get a Preval
spray can to apply in these areas before the big-spray.
You could also use this idea in your case, spraying small areas
with Preval sprayer and the primer you intend to use.
If priming and block sanding to level the panels, you cannot simply
strip it away after ... back to wavy panels.
Imagine how wavy this would be after removing the primer.
http://NHvette.com/ftp/in/as_she_sits_05_12_06.jpg
I decided against seaming the bumper in ... too much sanding and 'glass work as it is.
Old Aug 29, 2006 | 04:57 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
Dupont offers a primer in a spray can, I'd reccoment that out of anything else in a rattle can
clicky
Old Aug 29, 2006 | 06:44 PM
vettfixr's Avatar
vettfixr
Check with Eastwood. I think they have spray can primers that are compatible with most auto finishes.
Old Aug 29, 2006 | 10:12 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Thanks everybody..... well, I guess I'm sanding most of the rattle can stuff off anyways....
I just got my paint gun today, hopefully get the compressor next weekend..... then I can spray some primer/sealer and see how good I am at painting
Old Aug 29, 2006 | 10:35 PM
roger55's Avatar
roger55
RedBad,
You are not getting the correct advice here.
Go to www.hotrodders.com.
Sign up and post your questions like this on the "Body-Exterior" forum.
Many pros hang out on that forum and you are going get excellent advice there.
I guarantee you will get hooked on that forum.
Sent you a pm.
Old Aug 29, 2006 | 10:39 PM
roger55's Avatar
roger55
Advice that will most certainly ruin a paint job.
Old Aug 29, 2006 | 11:21 PM
roger55's Avatar
roger55
Best thing to do is remove all the primer. Then spray it with a high-build polyester primer like Evercoat Slick Sand or Featherfill G2 and re-block the car flat. Believe me, you can block the car perfectly flat very fast using this stuff. Leaving old lacquer primer on a car is not a good idea. Yea, you can get away with it if you seal it like you say, but it is not the best way to go.
It would be better yet to strip the car completely, shoot with epoxy primer and then go with the polyester primer. Then, final prime it with a urethane primer before topcoating.
Old Aug 30, 2006 | 02:32 AM
c3 in hawaii's Avatar
c3 in hawaii
all the way.. When I was getting my '78 ready for paint, I covered it with spray can primer... The painter wouldn't touch it until I sanded all of it off... I'll never do that again. what a PITA!
Old Aug 30, 2006 | 06:39 AM
Corz's Avatar
Corz
RedBad,
excuse me? are you saying I dont know what I'm talking about?
Old Aug 30, 2006 | 08:06 AM
NHvette's Avatar
NHvette
snip .... Yea, you can get away with it if you seal it like you say, but it is not the best way to go. ... snip
I think that's the most agreeable post I've ever seen from roger55.
Old Aug 30, 2006 | 08:27 AM
VettePower's Avatar
VettePower
Listen FOOL... I dn't know who the heck you are, but I have been painting cars for years, and you are fulll of BS. You use a good primer-sealer you will not have any problems. So keep your insults to yourself or learn what the heck you are talking about. Nuff said.................
Old Aug 30, 2006 | 08:47 AM
roger55's Avatar
roger55
I didn't mean it as an insult to you personally. I am sorry you took it that way.
Obviously, I still disagree with your advice. Using rattle can primer on a car is a bad idea.
Old Aug 30, 2006 | 09:02 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I'm not using it to prime for paint, only to help me see high and low areas while sanding.... right now I have some red color left on the bumpers, there is brown primer, greenish/white fiberglass jelly and yellow body filler.... impossible to tell if the panel is straight
Most of that rattle can stuff is going to be sanded off anyways.
Roger, I spent some time on that Hotrodder website... now I have a headache.... information overflow....
I'm hoping that I get my compressor next weekend, I'll likely prime the underside of the hood first. If I don't post about this two weeks from now it's because of embarrassment (might be frustration, too)
Old Aug 30, 2006 | 09:59 PM
bondoboy's Avatar
bondoboy
The spray can primer is uncatalyzed and will be the weak point of your paint job. There is no reason to apply good paint over cheap primer. Use a urethane fill primer. This stuff goes on way thicker than any spray can primer will.
To rattle can primer
