c3 tuning help
Old Aug 29, 2006 | 08:51 PM
mark werner's Avatar
mark werner
Default c3 tuning help
Recently rebuilt a 72 454 270 hp. corvette. engine has been rebuilt and I installed edelbrock torker 11 intake, msd distributor and msd ignition 6a system, and a edelbrock 1806 thunder series carb. Put in AC R43t plugs gapped at .040 as told by MSD. Under heavy load the car blows some black smoke out the pipes. Does anyone have any suggestions on rejetting sizes and metering rods and springs I may want to try. Can that be the problem? Any help would be greatly appreciated. Also, how do I determine want the total vacuum advance should be and is that the same as what dwell is as noted on car label when points are involved. Thank you!!
Old Aug 29, 2006 | 09:35 PM
MsVetteMan's Avatar
MsVetteMan
Wow. Lotta questions. Black smoke = rich burn. EB carbs have to have a fuel regulator on the older models. Read the manual, or go to the Edelbrock website and download it. Rejet. Pull a plug or two and take a look, let us know what you find.
