How long til it starts.
Old Aug 30, 2006 | 02:42 AM
JustForFun's Avatar
JustForFun
Default How long til it starts.
One thing i can say about my vette is it has always, even with the carb, had a instant start. hit the key and it fires before it makes a 1/4 turn. Its always impressed me that it starts so quick....cold, hot makes no difference
any others?
How long does it take for yours to fire up?
Old Aug 30, 2006 | 03:07 AM
another-user's Avatar
another-user
if everythings running good, probably 30 seconds or so. as soon as i get in the car i pump it 5 times then let it sit for a moment and then try. when its turning over i stand on the pedal and it normaly goes.
Old Aug 30, 2006 | 03:12 AM
rihwoods's Avatar
rihwoods
78....two pumps cold...none afterwards..
69.... one pump cold only..shuting it off is the hard part..
Old Aug 30, 2006 | 03:16 AM
another-user
that reminds me, its more supriseing if the car doesnt diesel when i shut it off then if it does.
Old Aug 30, 2006 | 03:35 AM
standup's Avatar
standup
In 4 years, I've only ever had one problem starting....that's when the solenoid screws had backed off the starter....I quick fixed it by pressing a wooden hammer handle over the solenoid while a mate cranked her over.....
Every other time, even when I had a hack of an engine, it's fired right up....no cranking
Old Aug 30, 2006 | 03:36 AM
standup's Avatar
standup
You should get the dieselling problem sorted out
Old Aug 30, 2006 | 04:18 AM
Bob Onit's Avatar
Bob Onit
Well........ If I can beat 1/4 turn then I would have to say "Instant"
3 pumps when cold and thats it...it fires right up
I honestly dont think the engine makes a full revolution before it starts when its warmed up..Click..bang, its running.
I did a compression test last week and to hear the starter turn so many times made me cringe.
I suppose since I have a low HP/Compression engine the starter will last many years....
I would gladly trade replacing the starter every year for some more HP which will hopefully be the case before the end of September As I plan on rebuilding the top end with the help of a good friend ...
Old Aug 30, 2006 | 07:19 AM
SIXFOOTER's Avatar
SIXFOOTER
Mine always fired right up except after I parked it for months at a time
Old Aug 30, 2006 | 08:54 AM
PatsLs1vette's Avatar
PatsLs1vette
MIne fires instantly no matter how long it sits.
Old Aug 30, 2006 | 09:11 AM
1Z87L8's Avatar
1Z87L8
my 78 ,if im starting it every day 1 pump
after it has been sitting like it has for almost
2 weeks now 4-5 pumps
Old Aug 30, 2006 | 11:26 AM
Q's 68's Avatar
Q's 68
My 68 fires up after one pump
Old Aug 30, 2006 | 01:02 PM
JustinD's Avatar
JustinD
A couple pumps and then crank while administering more gasoline. She is a thirsty sucker.
Old Aug 30, 2006 | 01:58 PM
682XLR8's Avatar
682XLR8
One maybe two turns to wake up the neighbors
Old Aug 30, 2006 | 09:05 PM
kdf1986's Avatar
kdf1986
On my 1972 it will start up anytime with 1 pump, and about 3 seconds.
My 73 bb takes a little longer, between 5-10 seconds, and 3 pumps
My 75 L82 will start within 3 seconds ..IF it has been driven the day before..and more than 30 seconds and unknown pumps if it hasnt.
My 86 will start in 1 second. You hear the motor start to turn, and its started already. ( fuel injection is great!)
kdf
Old Aug 30, 2006 | 09:22 PM
mkflanagan's Avatar
mkflanagan
Mine starts within 3 or 4 seconds but if its cold I have to keep the rpm's up for a minute or so because the choke on my quadrajunk is inop.But i'm still impressed how easy a 30 year old motor that has never been touched fires up.
Old Aug 31, 2006 | 01:00 PM
C3 4ME's Avatar
C3 4ME
Not as easy as some of my other Q-jet cars I've had in the past. It cranks for a few seconds after sitting for a week or more. Now, once it's warm ,it'll start right up. I did notice though coming back from Carlisle, it doesn't like to start after a long highway run. It seems to be flooded and kicks out black smoke for a second or so. Lars are you listening? When are you going to be doing carbs again, I need your help!
Old Aug 31, 2006 | 01:09 PM
MartyW's Avatar
MartyW
Depends on the mood of the car. Sometimes it will start up right away and other times it will take a few cranks. I never pump it with gas before I try and crank it because if I do it will flood the carb - ALWAYS. I think that is because if my airgap manifold so I have learned not to pump it. As for the deiseling that someone else mentioned, either get that fixed rather soon or get in the habit of turning off the car while it is still in gear so it will not do that. I had a slight problem with that for a while because I was running too hot, so I got in the habit of turning off the car in drive and would never diesel. Got the temps fixed so that does not happen anymore.
To How long til it starts.
Old Aug 31, 2006 | 02:59 PM
justanotherdoe's Avatar
justanotherdoe
1 pump to set the choke and it fires immediately (stock rochester quad, rebuilt in last 4 months). I do drive it everyday to work - stays happy that way!
Old Aug 31, 2006 | 03:04 PM
Xakk's Avatar
Xakk
1 pump, start die. Start again and stays running. It's done this as long as I've had the car and no amount of fiddling with the time seems to change it. I figure at least it's reliable.
Old Aug 31, 2006 | 03:19 PM
pws69's Avatar
pws69
A little more tension on the choke spring when it's cold should cure that.
