1979 driverside window removal
Old Aug 30, 2006 | 07:18 PM
dmoff1's Avatar
dmoff1
7th Gear
Default 1979 driverside window removal
I have 1979 L-82 that I am in the process of restoring(first vette) The gear on the bottom of the electric window has had the teeth ground off of it. I have removed the motor,but can't figure out how to get this gear off.
Old Aug 30, 2006 | 07:38 PM
SIXFOOTER's Avatar
SIXFOOTER
ya got to drill out the rivits or spot welds to get the regulator assy out and remove the track off the window, there is a nut on each end. There is a hole in the regulator to put a bolt in to keep the thing from scissoring your fingers, be carefull
