Build Sheet Blues
Old Aug 30, 2006 | 10:22 PM
eileenthevette's Avatar
eileenthevette
Default Build Sheet Blues
Fuel tank was dropped today for maybe (it looked like) first time in 37 years. Guess what I found? Nothing but that blob of glue in the center of the picture, where my build sheet used to be.
Old Aug 30, 2006 | 11:43 PM
Z-man's Avatar
Z-man
At least you had the glue...I didn't even see that when mine was dropped...
Old Aug 31, 2006 | 01:29 AM
Muddywaters's Avatar
Muddywaters
Un-lucky...sorry
Old Aug 31, 2006 | 10:32 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Sorry, but all too typical. Most of our tanks look exactly like yours because most of us find nothing when we get there, or what little we do find is illegible.
The lucky ones are those who actually find a sticker and can read it.
Old Aug 31, 2006 | 12:06 PM
eileenthevette
I've heard you can get a copy at the Corvette Museum, but only for certain years? Is that true?
I had also heard that many of the old ones were destroyed by GM?
Old Aug 31, 2006 | 12:52 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
Question why did you pull your tank ? And was it a big deal?
Old Aug 31, 2006 | 01:17 PM
Easy Mike's Avatar
Easy Mike
PM sent.
Old Aug 31, 2006 | 01:29 PM
eileenthevette
Decided to go ahead and do body off. So I'm pulling everything possible off before doing so. Plus I was anxious to find that elusive build sheet.
No, it wasn't too hard. Had to remove exhaust and spare tire tub top & bottom. Then it's just 2 fuel hoses (supply & return), 2 wires, 2 rusty strap bolts & 4 rusty support bolts. Drop the support member, pull the straps, tilt the tank, and it comes right out.
Don't forget to remove fuel first, have a fire extinguisher handy (points from Bob Onit? ) and wear safety glasses 'cause the dirt & dust that falls is amazing!
I found a couple of slackers hanging around the house to help.
Old Aug 31, 2006 | 03:39 PM
71-Stingray's Avatar
71-Stingray
I know about the missing build sheet - I found exactly the same thing when I dropped my tank. Bummer!
Old Aug 31, 2006 | 05:00 PM
69monzacpe's Avatar
69monzacpe
Here's a bummer story. Pulled mine years ago, was able to read it and wrote down everything. Put it in a "safe place".
A relative (won't mention any names) was cleaning one day, and through out some "junk", which included the copy of the sheet...
Makes me want to
Old Aug 31, 2006 | 05:08 PM
stinkray's Avatar
stinkray
I pulled the body off of a '76, the build sheet was there with about 1/8" of dust on it. After ever-so-gently brushing off the dust with a piece of cheese cloth, i was left with a crispy, crunchy, blank piece of yellowed paper.
Old Aug 31, 2006 | 06:37 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Can I have your "glue spot?"
Old Aug 31, 2006 | 09:50 PM
eileenthevette
Sure! That's about the size & shape. I'll scrape it off for you tomorrow!
Old Aug 31, 2006 | 10:41 PM
fotyfobravo
Send those 2 "slackers" with it....My garage needs a good cleaning!
Old Sep 4, 2006 | 08:59 PM
tecjr's Avatar
tecjr
7th Gear
I am in the same situation. I dropped my tank today and find tiny scraps at the corners of the build sheet - enough to prove it was there but no info. Did you get an answer to your questions about copies at the Vette museum?
Old Sep 4, 2006 | 09:47 PM
eileenthevette
Yes. But they weren't good answers. Apparently if your car was pre '77 built at St. Louis, good luck. If it was 77-81 there is a company called Allied Vaughn that was hired to put records on microfiche. And the NCM is supposed to have MOST of the 81 and after (Bowling Green Plant) records. I must credit this wealth of knowledge to Easy Mike who sent it to me. He also sent me this link. Good Luck.
http://www.corvetteactioncenter.com/...x.php?cmd=area
Old Sep 5, 2006 | 08:35 AM
cosmicvette's Avatar
cosmicvette
it is a bummer, but oh well, at least you enjoyed the company of your helpers....I don't have my build sheet either, but hey, the build sheet doesn't drive the car so I don't care! the enjoyment is in the driving.
Old Sep 5, 2006 | 09:00 AM
eileenthevette
You're right cosmic. I didn't really expect to find it anyway. I think my helpers were more disappointed than I was. Ah, the optomism of childhood.
To Build Sheet Blues
