TACH don't work ??
Old Sep 5, 2006 | 11:19 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default TACH don't work ??
74 454 ... I know that the tach and cable are fine, as the tach will jump when I spin the cable by hand.
Assuming the drive gear on the distributor shaft is ok....what are the pieces called that I need to repair?
Thanks....
Old Sep 5, 2006 | 11:34 PM
zzyzx's Avatar
zzyzx
Been there, done that. The most likely culprit is your tach-drive gear. They are as reliable as my ex. All of the vendors sell an upgrade needle bearing drive that I have used, and no problems since, but it will spank you for $75
Old Sep 6, 2006 | 08:21 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Drive gear and distributor shaft. When these fail, it usually chews the teeth off both.
Old Sep 6, 2006 | 11:30 AM
merlin5353's Avatar
merlin5353
St. Jude Donor '07-'08-'09-'10
Any other work around fix for this? (read: cheap)
To TACH don't work ??
