California Smog Test
Old Sep 6, 2006 | 07:58 PM
Bobbymays's Avatar
Bobbymays
Default California Smog Test
Need advice on getting my 76 through the Smog test. Has a new turn key 350 fron engine factory but still test high CO.
bobby
Old Sep 6, 2006 | 09:09 PM
The3's Avatar
The3
Others have claimed to make sure it's tuned up, increase the idle a bit, and make sure the cats are really hot. Good luck
Old Sep 6, 2006 | 09:20 PM
Bobbymays's Avatar
Bobbymays
Thanks The3
Old Sep 6, 2006 | 11:41 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Do you know what the readings for CO and HC's are? CO readings can escalate for a variety of reasons (of course like anything else) but check it for vacuum leaks and make sure the EGR valve is working properly.
I don't think that getting the Cat hot is going to help with Carbon Monoxide but I could be wrong.
Old Sep 7, 2006 | 06:28 PM
Kalway's Avatar
Kalway
get 3/4 tank of premium and 1/4 E85. That'll knock those CO levels down a bit.
Old Sep 7, 2006 | 06:36 PM
rihwoods's Avatar
rihwoods
bobby
Here are my 78 results...hope info helps..
In addition to EGR valve mentioned above,get fresh oil change,plugs,tune carb(clean) and get the cat good and hot...
Good luck
Actual mileage was 126,512
Rich
Old Sep 7, 2006 | 07:22 PM
Kalway's Avatar
Kalway
Test weight 4000 lbs? Wtf were you carrying in there? 12 sandbags?
Old Sep 7, 2006 | 10:20 PM
aocm77's Avatar
aocm77
Default Passed!
Good luck
Rich
Great advice, worked for my 78 SA!
Old Sep 7, 2006 | 10:57 PM
rihwoods's Avatar
rihwoods
They did not weigh it...if they had,it would be 3580...that is on Edco's certified scales..
Old Sep 8, 2006 | 02:38 AM
Kalway's Avatar
Kalway
Ah... those cheaters!
Ey get any info on some smog guys for me yet? Still waiting on try #4 for historic plates now. Crossing my fingers that someone with half a brain actually gets my application this time.
To California Smog Test
