pump for wind shield wiper
Old Sep 10, 2006 | 11:50 AM
teparc's Avatar
teparc
Default pump for wind shield wiper
does any body know how to remove the cotainer that has the cleaner for the windshield.going to replace it and the pump on a 75 convertible.thanks
Old Sep 12, 2006 | 05:32 PM
RaceCarRob's Avatar
RaceCarRob
3rd Gear
I have the same problem with my '74. I've heard/read that the only way to get at it is to "remove the master cylinder", pull out the reservoir, and replace the pump. Geez. I can't believe there's no easier way. And if there's not, I'll wait for the master cylinder rebuild (power brakes on mine) to replace the washer pump.
Old Sep 12, 2006 | 06:03 PM
Vette Gator's Avatar
Vette Gator
This is how I had to do it, but I didn't remove the lines from the master cylinder. Carefully moving it toward the valve covers gave me enough clearance to get the reservoir out.
Old Sep 12, 2006 | 06:32 PM
SIXFOOTER's Avatar
SIXFOOTER
you may not have to take the container all the way out, I got mine out by taking the container loose, then uses a deep socket to take the nut off inside and slip the motor/pump out of the bottom
Old Sep 12, 2006 | 06:34 PM
onaqwst's Avatar
onaqwst
since i dont plan on using my washers, i just took a utility knife and cut the bottle in half........ no, i'm trying to remove the charcoal canister and i think i might have to take off the MC....wtf......unless i fond another way
b
To pump for wind shield wiper
