doors ??
Old Sep 11, 2006 | 07:08 PM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
Default doors ??
I found a set of very clean doors off a 1980 vette, would they fit my 73 ??.
Old Sep 12, 2006 | 12:08 PM
markdtn's Avatar
markdtn
Yes, but the inside part is completely different. The inside handle and lock stuff are in very different locations.
Old Sep 12, 2006 | 04:45 PM
Michel B's Avatar
Michel B
In other words, no good for me if I want to stay original. Thanks
Old Sep 12, 2006 | 09:02 PM
CF6873's Avatar
CF6873
You would just have to remount your inside door handle and add clip nuts for the door pull. I did exactly this on my 73. Also the window motor has a different plug on it, but the vendors sell an adapter for the wiring harness.
Old Sep 12, 2006 | 09:18 PM
Michel B's Avatar
Michel B
So it can be modified to accept the 73 panel ? ok, so I guess its worth looking into then.
Old Sep 12, 2006 | 09:24 PM
CF6873's Avatar
CF6873
It's been a couple of years since I did mine but I think the bolt holes were already there for the lock and handle assembly. I then put on the door panel and scribed marks for the door pull. then with a dremel I cut a slot to accept a slip on clip nut for the door pull screws.
To doors ??
