Finally Let it Rip
Old Sep 13, 2006 | 12:00 AM
b71vette's Avatar
b71vette
Default Finally Let it Rip
Well I have had the 383ci/489hp/495tq/M21 4speed stroker in my 71 for a while now. And have not really gotten down on it off the line. Dang I don't know what got into to me. I was on a slight incline, a neighbor asked me to rev the engine to listen to it, so I took my foot off the brake to rev the pedal. And before I knew it I was smokin the tires and 150 feet down the road, before I let off of it. It's gonna be difficult to stay out of trouble with this beast, took me a while to regain my composure.
Old Sep 13, 2006 | 12:36 AM
gator79's Avatar
gator79
what took you so long?
Old Sep 13, 2006 | 01:51 AM
bluegtp's Avatar
bluegtp
wow, sounds like fun!
I'm about to build a 383....can you tell me a little more about your set-up.....heads?....stoker kit?....cam, intake, etc????? I just got my scat kit in today!....about to buy some brodix heads and everything else...
thanks!
ryan
Old Sep 13, 2006 | 02:15 AM
DMONSVETTE's Avatar
DMONSVETTE
Pics?
Old Sep 13, 2006 | 09:48 AM
MsVetteMan's Avatar
MsVetteMan
Dat's a beast of a 383........need the spec's on that build!!
Old Sep 13, 2006 | 10:08 AM
69monzacpe's Avatar
69monzacpe
So it was an accident then that you did a 150Ft burn out?
Have fun, but watch the mirrors!!!
Old Sep 13, 2006 | 08:33 PM
b71vette's Avatar
b71vette
specs:383 STROKER, AFR195 heads, 750DP Speed Demon, Performer RPM Airgap, MSD Ignition, Jet-Hot Hedmans, solid roller cam, 370 rear gears
pics:
Old Sep 13, 2006 | 09:23 PM
MsVetteMan's Avatar
MsVetteMan
Wicked. Now will you share the internal specs?
Old Sep 13, 2006 | 10:04 PM
slowup's Avatar
slowup
Old Sep 13, 2006 | 10:06 PM
Muddywaters's Avatar
Muddywaters
Lookn' good & fun!!!
Old Sep 13, 2006 | 11:32 PM
b71vette's Avatar
b71vette
internal specs:
4bolt main bored .030 over, Scat 9000 series crank/internally balanced, Scat 6" forged IBeam rods, SRP Forged Pistons, Special Coated Race Series Main and Rod bearings, 1.6 ratio aluminum roller rockers, Melling High volume oil pump.
Sold Roller Cam
Intake Exhaust
Duration At 0.05 230 236
Lobe Lift 0.368 0.376
Lobe Separation 110
Old Sep 14, 2006 | 01:06 AM
bbeck's Avatar
bbeck
b71vette, what are you running for headers/exhaust? Do you have pics of the car from the side?
Old Sep 14, 2006 | 03:33 PM
ajrothm's Avatar
ajrothm
That is a BEAUTIFUL CAR! Nice work on the resto. Glad you are finally running it. With 489hp, you need to use em. Get that biotch to the track pronto! I bet thats a high 11 sec car if you can get it to hook.
Old Sep 14, 2006 | 03:57 PM
DeanW's Avatar
DeanW
Does the Air Gap fit under a stock hood?
Old Sep 14, 2006 | 07:48 PM
b71vette's Avatar
b71vette
The Airgap fits under the original LT1 hood. I have not done any resto on the body, here are a couple pics. I fabricated the 3" mandrel bent side exhaust using mandrel bends I purchased from Summit.
Old Sep 15, 2006 | 01:10 AM
bbeck's Avatar
bbeck
Looks good- I've been thinkin about doing something like this. Are those hedman headers? Did you use any baffles or is it straight through?
Old Sep 15, 2006 | 09:49 AM
7DStingray's Avatar
7DStingray
That sure look good
Old Sep 15, 2006 | 06:33 PM
b71vette's Avatar
b71vette
yep, they are hedman's, I used spiral baffle inserts
To Finally Let it Rip
